Question about Lowrance HDS-8
How do I turn on the sail trail on my GPS?
The sail trail was turned off and now cant turn it back on.
Posted by Tanya Weber on
GPS won't fully reset
Resetting will not delete tracks - you must delete the track(s) individually. Your manual is here. Turn to page 26 and read "Using Tracks" to learn how to delete them.
Dec 07, 2013 | Garmin GPSMAP 60CSx GPS Receiver
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
I have a trail blazer. i started it and it will
Check the shift interlock, it is designed to keep the vehical in park until the brake is depressed. Try turning the steering wheel (both ways if necessary) as you turn key to remove it
May 16, 2010 | 2008 Chevrolet Trailblazer
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
2. Press and hold the ZIN&ZOUT Keys at the same time
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
Cat was stolen by a cab driver. I have it on our video surveilance recording. He has in his cab a GPS for directions. Is it possible if I were able to get his GPS, to track his movement from the time he...
Hi there Roofer,
While that is all possible, in order to do it you would need to trace the cab either by the cab number or the drivers name and company.
If you already have this information (from the video), the best advice I can give you is call the police or animal control and make out a report. Then the GPS tracking records will corroborate your claims.
You may get better results with animal control. (BTW Animal control officers have authority to arrest). The tape you have will prove the charge.
Just don't let up, tell them you ARE pressing charges. With the evidence you have, what more could they need.
Best of luck to you
Mike
Mar 19, 2010 | Garmin nuvi 750 GPS Receiver
My camera is locked and i cant get the password to reset
I'm sure the Bushnell Trail Sentry User Manual can help you with this. See -Setup and Operation Guide - If the Sentry is turned on without a card in place, it may not turn off-reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Only remove or insert cards with power off.
Click on this link to buy additional Trail Scouting Camreras
Oct 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
LCX15 ci no trails
Check your settings. Menu>My Trails>Trail Options>Update Trail. If you uncheck the Update Trail option, automatic trail
creation will be turned off. This must be check to record and track.
Triton72
Jan 07, 2009 | Lowrance LCX-15MT GPS Receiver
Lowrance HDS-8 Logo
65 people viewed this question
Top Lowrance Boating Experts
Ekse
Mike
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
