Coby DVD-224 DVD Player Logo
Question about Coby DVD-224 DVD Player
Reset a coby 224 dvd player? T V is showing ''mode not supported'' resolution not supported, change the resolution of the external device
Everything
5 Related Answers
Anonymous
  • 95 Answers
SOURCE: Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
Posted on Aug 23, 2008
Anonymous
SOURCE: Universal remote for Coby 224 dvd player
Not certain, but have you tried Coby's 1086 code?
Posted on Jan 30, 2009
Anonymous
  • 563 Answers
SOURCE: coby 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, Coby is a company whose electronics cannot be controlled by any remote other than the one that came with it. This means there is no code available for universal remotes. If you need a replacement remote (it will be identical to the one that came with the unit) please call our customer service number above. They will take your information and provide you with the procedure for ordering a part from Coby.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
Anonymous
  • 563 Answers
SOURCE: Universal Remote Control
Anonymous
  • 563 Answers
SOURCE: philips universal remote not working for my coby dvd 224
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
How can I find/reset passwords on Coby 224S and Coby 206
http://www.dvddemystifiziert.de/codefree_en/coby.html
Unfortunately, I don't see Coby 206. There is a 207 however if that would work.
Unlock Coby DVD players - DVD hack
Coby DVD-201 / DVD-217 / DVD-224 / DVD-227 / DVD-237 / DVD-505 / DVD-514 / DVD-527
  1. Press SETUP
  2. Press VOL+, VOL-, VOL+, VOL-
  3. Current RC should be displayed
  4. Select the RC with RIGHT and LEFT (255=Codefree)
  5. Press SETUP
  6. Turn the player off
Coby DVD-202 / DVD-203 / DVD-207 / DVD-208 / DVD-218 / DVD-507 / DVD-508 / DVD-606 / DVD-615
  1. Method 1:
  2. Press SETUP
  3. Press 2, 1, 8, 8
  4. A new menu entry appears (Version)
  5. Select it
  6. Press ENTER
  7. Select "Region" with RIGHT
  8. Select RC with UP, DOWN (0 = codefree)
  9. Press SETUP
  10. Turn the player off
  1. Method 2:
  2. Press SETUP
  3. Press VOL+, VOL-, VOL+, VOL-
  4. Current RC should be displayed
  5. Select the RC with RIGHT and LEFT (255=Codefree)
  6. Press SETUP
  7. Turn the player off
5helpful
Philips universal remote not working for my coby dvd 224
6helpful
2answers
Remote control not functioning properly
It sounds like the remote needs to be replaced. Below is the procedure you would follow to obtain a replacement remote from COBY.
To obtain a replacement part from COBY, you must follow these instructions:
Please send:
1. A money order made out to COBY Electronics in the amount of $6.00 (FOR EACH PART ORDERED! -- TFDVD batteries cost $18.00)
2. A note with your full name, phone number, and return address.
3. A note detailing the model number of the device/unit and the part being requested.
4. If you're requesting a replacement remote please write the numbers found on the back of the remote on the note mentioned above.
We strongly suggest you either send the above requirements via certified mail OR with delivery confirmation which is available from the post office. And please hold on to your money order receipt/stub.
COBY will not make return shipments to a P.O. Box. For shipping to international addresses, actual freight will be charged. Please mail the above requirements to:
Customer Service
COBY Electronics Corp.
56-65 Rust Street
Maspeth, NY 11378
Failure to enclose the above requirements will result in a delay in the processing of your part request. Please allow 4 weeks for the processing of your request; allow 6 weeks during the November to February holiday season.
1helpful
1helpful
Does remote have audio volume adjust?
Unfortunately, the dvd 224 doesn't have a volume adjustment. The models that do are the ones that come with 5.1 surround sound speakers such as dvd 755, dvd 937, and dvd 958 just to name a few.
I reset the factory settings on my Coby DVD-224 and now I need to find out what the password is so i can watch my DVD's....
Did you use the reset instructions that are found on a sticker on the top of the player? If so, and the unit is still asking for a password, this might mean the V-Chip or parental guardian has been activated. Please call the customer service number above so see if there is a master password available.
Coby 224 wrong disc
1helpful
Coby-224 DVD
Reset back to default
make sure no disc is in the tray
press right on the remote 3 times
down arrow once time- right 3 times - down arrow once then press setup the enter.
Coby dvd-224 "loading"
If everything else seems to be functioning, try using your remote to reset the TV. There is a setting to switch the TV from being a TV to being a screen, or monitor, for the DVD player. What the button is labeled varies by manufacturer. It may be: TV/DVD, input, source, display, or something else. Display, for instance, displays the choice on the screen. Highlight and select DVD or perhaps the brand name of the DVD player.
This compliments of the Vancouver Radio Shack super geeks.
Top Coby Televison & Video Experts
Marvin
Marvin
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
