Ovens Logo
A
Anonymous Posted on Feb 17, 2015
Cannot turn the oven on
Turnng the temperature knob on
Rebecca
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Mar 01, 2015
Rebecca
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
295
Points
10
I have to press the two clock buttons together which gets the time to show, and stop flashing, only then will my oven come on.
Simon
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 22, 2015
Simon
Contributor
Level 1:
Answers
Questions
0
Helped
261
Points
0
I'm having the same problem with my whirlpool microwave/oven combination (model # Woc95ec0as). There's power supplied to the appliance, but none of the buttons work. This happened after some spurts of power outage.
  • Dyron Webb
    Dyron Webb Feb 22, 2015
    This could be the display board one with the buttons, the wide control board, or the MRC main board they are all tied together since the parts are not cheap an most places will not accept a return on electrical parts I suggest calling a repair service to have the testing done to narrow the problem I have seen this many of times after power outage most of the time it was the front display board but this was after testing
Dyron Webb
Level 2:
Champion:
  • Whirlpool Expert 220 Answers
  • Posted on Feb 18, 2015
Dyron Webb
Whirlpool Expert
Level 2:
Champion:
Answers
220
Questions
0
Helped
65917
Points
360
Too vague need model number an what steps you use to turn on
Parmco oven temperature knob stuck in how do I fix it please thx Tony
Hi Tony! If your Parmco oven temperature knob is stuck, you can try a few things to fix it. Here are some suggestions:
  1. Try applying some lubricant: You can try applying a small amount of WD-40 or silicone lubricant around the base of the knob. This might help loosen it up and make it easier to turn.
  2. Use pliers: If the knob is stuck, you can try using pliers to turn it. Wrap a cloth around the knob to protect it from scratches and then use the pliers to gently turn it. Be careful not to apply too much force or you might break the knob.
  3. Check for obstructions: Sometimes, the knob can get stuck because something is blocking it from turning. Check to see if anything inside the oven might be preventing the knob from turning.
  4. Call a professional: If none of the above solutions work, you might need to call a professional to come and take a look at your oven. They'll be able to diagnose the problem and fix it for you.
I hope these suggestions help you fix your Parmco oven temperature knob!
Mar 03, 2023 • Ovens
Nu-vu xo-1 convection oven temperature knob problem
Sounds like that nob is bad.can u get to see the nob wires to see what's up there?
Nov 14, 2013 • Ovens
How do I calibrate the oven temperature in a Premier 20 inch Freestanding Electric Range?
Pull the knob off of the spindle for the oven control. The temperature adjustment is done by turning the screw inbedded in the end of the spindle. Use a 5/64" blade screwdriver CCW to increase the oven temperature or CW to decrease. Make small adjustments until the dial setting matches the oven temperature.
May 04, 2017 • Ovens
How do I clean my oven? Model #RF354BXWD?
At the bottom of this is a link to the manual, it shows details starting on page 22 of how to clean.
Remove the racks and pans from the oven.
1. Move the Lock Lever to the right-the Clean position.
When the oven temperature goes above normal baking/roasting temperatures, the door cannot be opened and the Lock Lever must not be moved.
2. Set the Oven Selector and Oven Temperature Control Knob to
CLEAN.
3. Make sure the clock and Start and Stop Times all have the correct time of day.
4. Push in and turn the Stop Time Knob clockwise two or three
hours. The OVEN HEATING Indicator Light will come on. l Use two hours for light soil. l Use three hours or more for moderate to heavy soil.
NOTE: Make sure the Start Time Knob is not pushed in.
5. After the Self-Cleaning cycle is completed and the oven has
cooled enough, the Lock Lever can be moved back to the left.
DO NOT FORCE the Lock Lever. Wait until it moves easily. Turn the Oven Selector and Oven Temperature Control Knob to OFF.
6. After the oven is cool, wipe off any residue or ash with a damp cloth.
If needed, touch up spots with a soapy steel-wool pad.
Manual
2helpful
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 16, 2009 • Ovens
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
2helpful
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 • Ovens
Oven comes on and off on it's own.
YOU SAID:::>>>The knob for the oven (thermostat/temperature) is gone. The oven now comes on and off after it is used on its own. When turning it no longer stops where it should be at off or 0 degrees.
I SAID>>>>>thats it JGBC20BEA5WH but based on that model it is a gas unit the oven is >>>>controlled electroniclly<<<<< in the back control panel not sure of what know for a oven stat or knob your are adjusting?? plz help here
Apr 05, 2008 • Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
