Question about Dacor MCS230 Millennia Electric Double Oven
Can't find reset button on Dacor Dual Fuel Range RSD 305 ?
The reset button on the Dacor Dual Fuel Range RSD 305 is on located on the top of the oven chamber. To access the button you have to remove the long narrow metal panel located above the oven opening. It has a number of ventelation slots on each end, and it is held in by four screws.
With this panel removed you will have access to the space above the oven. At the front of this space, there is a group of wires and switches associated with the locking mechanism. BEHIND this large group of wires there is a second, smaller unit with a wire attached to each side. Between the two wires there is a small red button. Pushing down on this red button resets the oven.
Note that in my ten-year-old oven there was a lot of dust attached to the wires and mechanisms described above. Because of all of this dust it was difficult to see the red button.
Posted by mail181 on
1 Related Answer
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Posted on Jul 29, 2012
I have a Dacor ERD48SCH/NG oven/range. Accidentally changed the clock time to military (24-hour) time, and now can't figure out how to change it back. How do I change back to regular 12-hr time?
Step 1 Locate the "Clock" button on the display. The display is located above the oven door. It clearly shows the time and has settings for temperature, time and cooking.
Step 2 Press and hold the "Clock" button until the time starts to blink.
Step 3 Set the time with the number pad. Ignore the colons and enter the number straight through. For example, if the current time is 10:08, just type 1-0-0-8.
Step 4 Set AM and PM by pressing the "#" button. Press "Start" to finish.
Jul 07, 2018 | Dacor Ovens
F-1 showing on digital window of dacor dual fuel range with oven alarm beeping. Unit is turned off.
Your temperature censor may need to be replace. try geting the fault code diagram from the manufactor brand.
Nov 14, 2013 | Dacor Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Jul 28, 2012 | Dacor Ovens
I want to re-set high temperature limit control,
if you open the oven door all the way, then, look under the control panel (where the top of the oven door seats) you will see a plate that has 6 to 8 screws holding it in place.Remove the screws of that plate with a phillips screwdriver.You will possibly need a flashlight to look inside the space where the reset switch is located... but it is THERE. Make SURE that you TURN OFF the circuit breaker or... UNPLUG the range... B4 you proceed to reset. Look for the Red Button on the back side of one of the limit control switches. Press it in till it clicks. (sometimes you'll hear it... sometimes you wont). Plug baack in ro reset your breaker switch, Turn on your oven and see if it works. If it does... then replace the vent plate close your oven door and now your cook"n with gas...well... electricity really.
May 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
I want to re-set high temperature limit control, but don't know where it's located
Hello- The reset is located inside the oven at the top. Remove the screws and pull cover. Use a flashlight to find the little red button and push it in with a little screwdriver until it clicks. Should solve this problem. Wish all ovens had this button.     Please acknowledge this post if helpful.  Thanks- Ed
Mar 23, 2010 | Dacor ECS130 Epicure Electric Single Oven
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor range (oven)does not work
I have had the same problem for ten years. After a few years of the tech coming out everytime
I self cleaned, I had him show me how to reset, and he also gave me a new reset gizmo in
case that doesn't work. As for resetting, the top plate on top needs to come off and then you'll
see the gizmo with a dark red reset button that is attatched to the floor of that top compartment, which I leave unattatched for easier access. Push button down, of course turn off the electrical power to oven before doing all this. Works everytime.
May 29, 2009 | Dacor ECS130 Epicure Electric Single Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Dacor MCS230 Millennia Electric Double Oven Logo
401 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
