Question about HP Officejet J5780 All-In-One InkJet Printer
Hp J5780 all in one - I cannot get the printer to attach to the bottom portion.
I have tried for 45 minutes to attach the printer to the bottom portion. I can get one side to seat properly but cannot get the other side to fit. Is there something I am not doing right? The error code says cartridge is not aligned properly.
Rod Eslinger
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
Regarding your recent inquiry about the HP 74, 75, 74XL or 75XL ink cartridge error message ("Cartridges Not Aligned" or similar printer alert condition) and inability to print with your HP OJ J578 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside one of the ink cartridges (.....it is very rare for both cartridges to fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, and to confirm/determine which of the two ink cartridges is causing the failure condition, please run the 'Tap 41' cartridge's electrical diagnostic test below (refer to C.)
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC STEPS:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Print Extended Self Test:
    1.Press CANCEL + OK buttons at the same time.
    2.The extended self test page should print.
    --- Verify all colors and all stair-step nozzles are firing (i.e. no missing horizontal lines should be visible in the stair-step grid patterns). (NOTE: the self test page is a 'forced' test print whether the ink cartridges are good or bad). Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
    C.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure (or .pdf document) at the following links on how to activate and read the service test:
    http://inkjet411.com/?page_id=544
      1.Press the * and # keys simultaneously.
      2.Enter 124 (or 123) at keypad.
      3.Use the arrow keys to navigate to the System Menu. Select Ok.
      4.Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Should display 'code = 0'.
      5.Use the arrow keys to enter 'code = 41' (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern should begin to print.
      NOTE 1: The 'Tap 10' (extended self test) can also be activated by pressing CANCEL + OK buttons at the same time. Whether ink cartridges are good or not, i.e. this is a forced print test). Refer to following 4 paragraphs (or video) on how to interpret diagnostic report.....
      NOTE 2: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
      --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
      ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
      You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
      NOTE 3: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions. However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced:
      D. Cartridge Error Bypass ( Emergency Printing Only - http://inkjet411.com/?page_id=544 ):
      1. Press the * and # keys simultaneously.
      2. Enter 123 (or 124) at keypad. The 'Underware' menu should be displayed.
      3. Use the arrow keys to navigate to the Information Menu. Select Ok.
      4. Use the arrow keys to navigate to the 'checksum for relock data input'. Select Ok. LCD should display a 5-digit number after a few seconds.
      5. Attempt to send a print job to printer
      NOTE: with a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
      *Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
      For reference, the following page provides a complete review of the majority of cartridge error messages you may observe on your printer at one point or another:
      http://inkjet411.com/?page_id=509
      However, if your printer works routinely after inserting a brand new HP 74 and/or HP 75 ink cartridge in it, then this will confirm root cause of failure as being limited to one of the ink cartridges.
      For additional HP OJ5700 printer series diagnostics information please visit: http://inkjet411.com/?page_id=1813
      CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
      HP 74/75 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=WqnHRFpbo0w
      If you need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty (remanufactured ink cartridges which have been thoroughly tested; purchases are only available by USA residents).
      For any additional questions please contact us directly: [email protected]
Posted on Mar 03, 2015
5 Related Answers
AJAY MANJARIYA
  • 85 Answers
SOURCE: HP PHOTOSMART PRINTER C4280 PROBLEM: PRINTER WILL
what error u had got please tell me . also u can uninstall ur printer and again install it
Posted on Jun 03, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Posted on Jan 18, 2009
altaf702
altaf702
  • 28 Answers
SOURCE: HP OfficeJet 6110 All-In-One
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
Posted on Feb 28, 2009
Anonymous
SOURCE: hp psc 2210 all in one series printer: align cartridge repeatedly
Bypass the allign cartridge function bu pressand holding settup then press option. The printer will immediately acccept orders.
Posted on Apr 20, 2009
Anonymous
SOURCE: hp office jet j5780 cartridge error: cartridge on right must be replaced
Switch off, Remove catridge and Clean any leakage in the printer.
Clean the catridge with saliva if u do not have any cleaning liquide. Put the catridges back switch on and you are there. My hardware officer just tried it this morning and it worked like magic.
Note make sure all leakages are removed.
Posted on Jan 13, 2010
How can I get the HP officejet J5780 printer owner's manual?
Hi there !
You need to go to HP website to get free manual. Just type the HP officejet J5780 printer manual. Another way is to go through websearch, there are manual posted there for free download.
I hope help you find your problem. Regards.
Feb 02, 2011 | Office Equipment & Supplies
I just changed my black cartridge and the printing
Dip the bottom of the cartridge in some hot water. This should open the head so the ink can flow out freely. Once the ink is flowing into the water remove and dry the whole cartridge. Insert into printer and print.
Good Luck
Jul 20, 2010 | HP Officejet J5780 All-In-One InkJet...
Ineed driver printer HP J5780 all on line
Go to this site and download the driver
h20000.www2.hp.com/.
Jul 09, 2010 | HP Officejet J5780 All-In-One InkJet...
Hp officejet j5780, NOT SCANNING
go to www.hp.com and download a new driver of your scaner for xp
Jul 03, 2009 | HP Officejet J5780 All-In-One InkJet...
Manuel for j5780 all-in-one
Here is a link to the HP Officejet J5780 All In One Printer manual:
http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
Mar 19, 2009 | Office Equipment & Supplies
Loaded Software - Excel crashes after displaying print setup box.
The reson is because you have not installed the latest printer drivers. try updating printer drivers or contact you printer manufacturer for further assitance
Feb 06, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 : copy's and scan's result : black page
Try to disconnect the power cable from the back of the unit and reconnect it after few secs. The alingment will start itself. Complete the alingment once.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
I have an hp officejet j5780 all in one and am struggling to get it setup for the 1st time. Installed cartridges & following the alignment procedures. 1st part where it prints from the bottom tray is fine...
Normal 0 Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
179 people viewed this question
Ekse
efs_perpends
efs_perpends
