Question about Dremel Variable - Speed Multipro Rotary Tool 395
My flexible extension is not working on my dremel but the dremel works fine without it. What can i try to get the flexi hose to work?
I have unscrewed the flexi hose and re attached it. The flexi hose hasnt been attached for some time - don't know if that's the problem. My dremel is at least 10 years old
  •  Bob Oppenheimer
    Bob Oppenheimer Feb 17, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Model of the dremel and flex-shaft extension please.
    What exactly have you done so far and what is "not working"? Is flex-shaft bound up and will not spin. If you turn one of the flex-shaft end by hand does the other end spin? Since it has not been used in some time, you first want to find if the shaft is not bound up inside the sheath.
John Rogers
    New Friend:
    Problem Solver:
  • 7 Answers
I agree with raysaw - sounds like a job for WD40.
Posted on Feb 18, 2015
raysaw
    Sergeant:
  • 267 Answers
Can you turn the flexi hose by hand? if it turns does the other end turn with it? It could be broken inside or it could be seized. If it is seized you might try soaking it in some liquid wrench or other penetrating oil. If it turns freely and the other end turns it may be an attachment problem where the cable isn't engaged by the dremel.
My samsung star mobile is not working. the touch of screen is not working only hard buttons are working. please give the solution for this.
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care in solving the problem...
Aug 08, 2011 | Samsung SGH-L700 Cell Phone
The touch pad is not working on my Samsung GT-S5233A is not working
Take care
Jun 26, 2011 | Samsung Star GT-S5233 Cell Phone
My samsung transform touch screen won't work
my samsung transform phone the touchscreen doesnt work, just the key pad works . . . it doesnt make sence . i dont know what to do..please help
Jun 21, 2011 | Samsung Cell Phones
I bought htc touch 2 T3320. mobile 7 month before. now touch screen is not working properly. I tried soft reset many times. Then i tried hard reset. But no use. still screeen not working.
I hope this will help in solving the problem.....
Nov 25, 2010 | HTC Touch2 Cell Phone
My henry vacuum has lost suction and there's no blockage in the pipe.
Suction cannot be lost if the motor is running normally unless the air flow has been interupted. Lift out and clean the filter so air can flow through, replace the bag, unscrew the flexi hose at his "nose", and also remove from the steel pipes. Finally drop a
Sep 28, 2010 | Henry Vacuums
My asusp527 touch pad is not working how can i use mobile without touch pad
Touch screen
Take care
Aug 16, 2010 | ASUS P527 Smartphone
My LG Neon screen just stopped working! :( It works fine, the keyboard and bottom buttons and I can recieve calls, but the screen won't turn on at all. :( Helppp?
Good luck........
Aug 04, 2010 | LG Neon GT365 Cell Phone
How do you remove the plastic end fitted to the flexible hose
Not necessarily. Some Dyson models have an all inclusive flexi hose which attaches to the handle spine. Check EBay for replacement flexi hoses - UK has many sellers - or handles which have the metal pole and the flexi tube attached.
Alternatively take off the flexi hose from the bottom rear of the Dyson - it can come out via a press in lock release but it may take some time to do this. Once that is done the flexi hose should come down freely from the metal tube. If it doesnt then you may need to consider both replacements.
Dont forget to rate, thanks.
May 25, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Too much suction
Hi.
I have repaired Dyson machines for years & have never come accross this.
The only way you will have trouble extending the hose is if there is a blockage at the bend where you hold the wand could be a coin which when switched on flips accross & blocks oppening.
Is it easy to slide wand from flexi hose with machine switched off ?
If yes you probably have grit stuck under the collar that you push the button to unlock flexi hose from pipe.
http://dc07.atspace.com/
I will be logged in most of the time tonight if you need more help.
Chris..
Dec 23, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
145 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
