Epson Stylus DX8400 All-In-One InkJet Printer Logo
D
Donna Halliday Posted on Feb 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i scan photo with a5 paper - Epson Stylus DX8400 All-In-One InkJet Printer
Steve Mason
Level 2:
Sergeant:
  • Expert 311 Answers
  • Posted on Feb 18, 2015
Steve Mason
Expert
Level 2:
Sergeant:
Answers
311
Questions
0
Helped
57580
Points
687
What do you mean with A5 paper? do you want to scan an A5 sized picture, or put a picture on A5 sized paper?
How do I print on A5 paper on my TX300F?
A5 measures 148 × 210 millimeters or 5.83 × 8.27 inches. In PostScript, its dimensions are rounded off to 420 × 595 points.
You should be able to select A5 size in the Epson software, but above is a small idea of the sizes in case you have to setup manually, once you get it setup correctly then save it as a profile in the Epson software.If you are printing A5 then you need to make sure it is in landscape mode (if you are printing more than 1 page) if it is actual A5 sized paper or Photo paper then make sure gauge is moved on printer to the size of the medium being used.
With the espon TX810FW can i print on clear paper / over head projector sheets?please answer quickly it is important
You can get special overhead film for your Epson printer. It is coated for use in your printer, and has a backing sheet so the paper sensor can see that paper is loaded.
Printer sending out print crooked at the end of the page
Hi and welcome to fixya
the problem the you are telling is with your printer tray. check it carefully and adjust it with the given adjustments then paper should b came out smoothly
Canon MP520 printing on different size paper
Go in printer preference & select the paper at A5 & then print
Machine can not work with A5 paper.
Make your machine compatible with A5 paper. Go to Menu and then paper Alignment and click A5.
2answers
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Can Scan A5 size duplex
The software on my X4500 unit allows duplex scanning of A5 paper. Updating the firmware and software is fairly easy if you need to.
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
