It grinds the beans, but it does not dispense coffee, it does not tamp the beans, I only get water
SOURCE: Saeco Odea Giro highlights the "!" light and wont spurt water.
Try this open the steam knob for about 5 seconds then turn it to the rest(off) position, make sure that it is in the off position.
SOURCE: poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
SOURCE: Saeco Odea Giro - disassembly
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
