Question about GE 45231 Home Monitoring Camera
I just spliced open the wire coming out of the camera.it only has 3 wires.they are black,red,and yellow. so now i dont know witch goes where? need some help..
Need some help on what to do with this 3 wires. witch goes to what. a friend just gave it to me.but the wires have been cut.so now i need to find power supply and audio,video..
Neil Frazier
  • 42 Answers
Red & black is your power + & ground -. Yellow and black is your video and ground. you probably don't have audio if there is not another wire. If you have a shield wire around the others sometimes that is used for ground and in that case red and shield wire would usually be the power.
Posted on Dec 04, 2017
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: oven bake element
If you're talking about the wires attached to the BAKE element, normally RED is on the RIGHT and YELLOW is on the LEFT, but it really doesn't matter. Theoretically, this is a resistive heating coil and it will work with the wires connected in either direction. Normally, its fairly easy to determine how these wires reconnect, because the lengths are normally only sufficient enough to connect them one way.
The RED wire connects from the BAKE element to the terminal block, to one side of the BROIL element. The YELLOW wire is connected to one end of the BAKE element and runs to the electronic oven control (EOC) board.
I hope this clarifies this for you.
Posted on Aug 23, 2008
Anonymous
  • 4 Answers
SOURCE: Oven lower element wiring
I just looked at the back wiring of my JBP90 oven. The main element (bottom) has both black wires together on one element terminal and the single yellow wire on the opposite terminal. Not that it should matter, but both blacks are on the left and the yellow is on the right as viewed from behind the oven.
Good Luck!
Posted on Nov 22, 2008
Anonymous
SOURCE: Microwave blower motor wiring
I have an OH SUNG from a different model micro and have hooked it up every which-way I could and some how managed NOT to mess it up. I finally realized I needed the 6 microfarad capacitor across the RED and YELLOW. Works like a champ. ****** can move some air btw. I am thinking about thowing this puppy in my PC when I overclock it...
Maybe your VIOLET = BLUE and YELLOW = ORANGE?
Posted on Nov 25, 2008
Anonymous
SOURCE: Wiring diagram for Ramsond 18000 BTU Ductless
See link below for detailed wiring. I found it very helpful
http://www.ramsond.com/minisplit/wiring/detailedwire5170.pdf
Posted on Oct 02, 2009
bazking
  • 15 Answers
SOURCE: re wiring after someone disconnected
red and green is the phone in and the brown and grey are the phone out thats all u need make sure u connect it to the main line into the building as the pannel needs to have priority on the line
Posted on Mar 29, 2010
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
, 1-need schematic to rewire a lorex color camera model no:MC7555R i have five wires coming out the back of the camera 1'
The RED wire is your 12 volt power "positive". The BLACK wire is your 12 volt power "negitive" The YELLOW wire is your camera video. The white wire is your cameras audio & the copper wire is shielded ground.{Davesajak}
May 01, 2012 | Lorex SG6153 / Weather Resistant Mini...
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
Sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
I need to know witch plug wire goes where and the color of wire goes on top and bottom of the coils
Hi and welcome to FixYa,
To my understanding, for an 89-92 US/UK GSX750F:
  • left ignition coil supplies cylinders 1 & 4;
  • top terminal is white;
  • bottom is red/white;
  • right ignition coil supplies cylinders 2 & 3;
  • top terminal is black/yellow;
  • bottom is red/white.
Good luck and thank you for using FixYa.
May 15, 2009 | 1992 Suzuki GSX 750 F (Katana)
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
A/c wiring
The Red/White comes from the AC amplifier into the AC magnet clutch, from termianl 13.
The White/Blue wire goes back from the AC magnet clutch to the AC amplifier, terminal 14
The Black/White wire goes to two places, via a splice splice, 1 is to the relay box, Fan Relay # 3, and 2 is to the AC Magnet Clutch Relay.
Jun 15, 2008 | 1993 Toyota Camry V6
GE 45231 Home Monitoring Camera Logo
139 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
