Question about Chevrolet 2005 CHEVROLET TRAILBLAZER Radio a1z114572 AM-FM-stereo-cassette-sin
2005 Trailblazer, squeaking noise in the right and left rear after vehicle warms up after driving several miles and begins squeaking when hitting minor bumps in the road..
1. Thought it may have been door hinges, lubricated..2. Shocks replaced recently.. not even 500 miles after replacement.. 3. Check rear hatch, no problem..
Posted by Gregory Sanders on
Vernon Taylor
  • Chevrolet Master
  • 6,387 Answers
If it has a multi-link rear suspension that is fitted with rose joints it could be one or more of those.
Mostly in the case of vehicle noise assistants are needed to bounce the car to duplicate the noise while someone is underneath with a stethoscope listening.
Careful inspection with a good light can sometimes show something that has been moving that shouldn't be moving. Such things are often able to be seen by a different coloured line around the object or some rusty-coloured powder.
A vehicle mechanic would hope for a more comprehensive description than "squeak" as an aid to recognising it and locating it. Is it for instance, a rubber, plastic or metal type noise? Is it a noise that is heard only when large bumps are driven over or is it a more rapid jiggly sort of noise?
Accurately describing symptoms by painting a sound picture with words is of invaluable help...
Posted on Feb 17, 2015
What kind of service at 120000 miles
All of the following:
  1. Change all fluids including coolant, brake fluid, power steering fluid, transmission fluid, and crankcase oil. I would strongly recommend increasing the viscosity of your crankcase oil at this point, and use higher viscosity oil from now on. Change the oil every 3000 miles from now on as well.
  2. Replace oil filter and transmission filter.
  3. OVER-LUBRICATE (really) all lubrication points on the suspension, pushing out and wiping off as much old grease as you can. Inspect all bushings for signs of cracking, wear, or chapping.
  4. Perform a MAJOR TUNE-UP, replacing spark plugs, wires, and coil packs.
  5. Check all brake systems for signs of wear and proper operation.
  6. Re-pack all wheel bearings, inspecting them for excessive wear or failure.
  7. Check front tires for uneven wear. Perform a front-end alignment if there is any uneven wear or cupping on the front tires.
  8. Rotate tires, inspecting wheels for cracks or other damage.
  9. Check all lights and signals for proper operation and full illumination.
  10. Use penetrating oil on the battery connections to eliminate and prevent oxidation of the terminals.
  11. Lubricate all power window mechanisms, door latches, door hinges, and power seat mechanisms.
  12. Lubricate hood release, trunk release, and any other hinges in the vehicle.
  13. Use electric-safe penetrating oil (such as WD-40) on all switches, wiping off excess lubricant.
  14. Go a little crazy with the penetrating oil on anything that moves or pivots, again wiping off any excess.
  15. Tighten anything loose on the interior.
  16. Clean the throttle body using OXYGEN SENSOR SAFE throttle body cleaner (if you're unfamiliar with the correct procedure, look it up or ask me).
  17. Replace the fuel filter.
  18. Add a bottle of FUEL INJECTOR CLEANER to the tank. Don't add any more fuel until the tank is nearly empty.
  19. Check the operation of the shocks/struts, and replace as necessary.
  20. Check for engine codes and correct any identified errors.
That should keep you busy for awhile :) It's worth it.
Jul 25, 2014 | 1999 Mercedes-Benz E-Class
Trying to find the owners manual for 2001 saturn sc2 as well as the maintenance schedule etc provided when the car was new
Scheduled Maintenance The service shown in this schedule up to 150,000 miles (250,000 km) should be performed after 150,000 miles (250,000 km) at the same intervals.
See Owner Inspections and Services for maintenance information.
Scheduled Maintenance Mileage
Maintenance Group No.
6,000 Miles (10 000 km)
18,000 Miles (30 000 km)
30,000 Miles (50 000 km)
36,000 Miles (60 000 km)
42,000 Miles (70 000 km)
50,000 Miles (83 000 km)
5
54,000 Miles (90 000 km)
60,000 Miles (100 000 km)
6
66,000 Miles (110 000 km)
72,000 Miles (120 000 km)
78,000 Miles (130 000 km)
90,000 Miles (150 000 km)
7
100,000 Miles (166 000 km)
8
102,000 Miles (170 000 km)
108,000 Miles (174 000 km)
114,000 Miles (190 000 km)
120,000 Miles (200 000 km)
6
126,000 Miles (210 000 km)
138,000 Miles (230 000 km)
150,000 Miles (250 000 km)
5
Maintenance Requirements - Group 1 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). Maintenance Requirements - Group 2 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Inspect the engine accessory drive belt and coolant hoses every 12 months or 18,000 miles (30,000 km), whichever occurs first. Maintenance Requirements - Group 3 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Replace the engine air cleaner filter every 36 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Inspect the vacuum lines/hoses every 24 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Replace spark plugs. An Emission Control Service.
Oct 05, 2010 | 2001 Saturn SC
Rear Shocks ?
Go over to benzworld.org alot of specific groups that can get you better information.
Jun 03, 2010 | 1995 Mercedes-Benz S-Class
How often should i change my air filter and spark plugs?
Hello there
here is the maintenance schedule in detail
Group 4:2002 and newer X-Type, 2000 and newer S-Type, 2003 and newer XK8 and XJ8 Annually or every 7,500 miles
  1. Change engine oil and filter with Mobil 1 0-40 or extended performance 5-30
  2. Check and top all other fluids
  3. Visually inspect undercarriage for problems
  4. Inspect tires and rotate every second small service
  5. Check wiper blades, replace if streaky
  6. Check windshield washers
  7. Check lights
  8. Check belts and hoses
  9. Check operation of air conditioner and heater
  10. Road test car and note any problems
Every 15,000 miles this work is added:
  1. Replace wiper blades and clean washer nozzles
  2. Use Autologic to check for stored faults in the various computer systems
  3. Check handbrake operation
  4. Lubricate door locks
Every 30,000 miles this work is added:
  1. Inspect exhaust system and service as needed
  2. Replace air filter
  3. Replace cabin filter
  4. Inspect battery and replace if 4 years old or if it fails load test
  5. Check serpentine belt condition - replace if cracked. Check tensioners and rollers.
  6. Inspect brake discs/rotors
  7. Inspect brake fluid level, brake hoses, and brake pads
  8. Inspect cooling system
  9. Inspect door hinges & locks
  10. Inspect engine
  11. Inspect engine mounts
  12. Inspect exhaust system
  13. Inspect fuel system
  14. Inspect handbrake
  15. Inspect headlights, check aiming
  16. Inspect lights & controls
  17. Inspect seat belts
  18. Inspect steering system
  19. Check wheel alignment (front)
  20. Inspect wheel lug nuts
  21. Lubricate accelerator linkage
  22. Lubricate brake pedal
  23. Lubricate weatherstripping
  24. Torque propeller shaft bolts
Every 3 years this work is added, regardless of mileage traveled
  1. Change brake fluid, preferably in spring
  2. Change engine coolant, preferably in fall
Every 60,000 miles
  1. Change transmission fluid
Every 90,000 miles
  1. Replace spark plugs
  2. Change final drive lubricant
Oct 29, 2009 | 2002 Jaguar X-Type
A message stating service B in 500 miles
Service B means that there is a major service due. Brakes are not related. You will get a break warning light when they are due. The B service includes Oil and filter, Interior dust filter, Tire rotation, check of all the fluids, Lubricate all door and trunk hinges, and engine air filter. Also brake flush every 2 years.
Apr 26, 2009 | 2007 Mercedes-Benz C230 Sedan
2004 cts cadillac trunk will not open with remote or with button on drivers door.
if you here a clicking sound when you push the remote or the drivers button then the solenoid and fuse are probably o.k. lubricate the trunk lid catch and operate the latch a few times, also check the tension on the trunk itself , it should lift up part of the way by itself, if not 1. lubricate the hinges and move trunk lid up and down. if still bad 2. if it has a tension rod adjust the rod to a stronger setting if it has gas shocks, 3.replace shocks. if no click and fuse is good solenoid may be bad
Apr 23, 2009 | 2004 Cadillac CTS
Rear wiper and Rear defrost not working
jmdevan: There is a harness that runs through that hatch that controls all 3 of these. Either there is a fuse blown to that harness or the harness got disconnected (uhaul??)
Do you have tail/brake/backup lights?
Look in your owners manual and see if there is a common fuse for these 3.
It's got to be one of these 2 problems.
My money is on Uhaul breaking the power to these 3 when connecting the trailer harness.
Aug 01, 2008 | 2005 Toyota Matrix
Chevrolet 2005 CHEVROLET TRAILBLAZER Radio a1z114572 AM-FM-stereo-cassette-sin Logo
803 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Vernon Taylor
gludwick2
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
