Question about Tamron Cameras
I have a tamron lens need ti be clean and replace the rubber grip pls. Give a a service center or accredited service center with address here in manila thnx
Posted by ricky fabrigar bate on
Ric Donato
    Novelist:
  • Tamron Expert
  • 232 Answers
After doing a Google search this link may help you:
https://www.google.com/search?client=safari&rls=en&q=tamron+lens+repair&ie=UTF-8&oe=UTF-8
Posted on Feb 19, 2015
2 Related Answers
Anonymous
SOURCE: ERROR 99
I have faced similar problems previously with my Canon 20d and Sigma 170-500. Its even more annoying to see it happen in field while it would be okay back home. I was told that it is electronic compatibility problem instead of complaining the best was to change the lens and hence bought a 100-400 and happy ending.
Posted on Sep 29, 2008
Anonymous
  • 149 Answers
SOURCE: tamron 35-105 f2.8 sp lens, aperture often
lens flexible pcb broken change it
Posted on Sep 09, 2009
Pls. po can u help me to find tamron lens service center here in manila
Using Google search I came with this link:
1helpful
I have a tamron 70-300mm i had a canon 1000d and the lens worked pefectly fine with it but nw i hav purchased canon 550d and when i conect my tamron lens with it , it shows an error 01 please assist me
This is the kind of error which you always risk these days in buying lenses which are not from your camera manufacturer. Error 01 simply means that the camera cannot communicate with the lens. Canon's protocols are not open standards and third party manufacturers have to reverse engineer to produce something which works. As they're working in the dark, they cannot always arrive at a solution which makes all models suit all Canon bodies.
You have two possible solutions:-
Visually inspect the contacts on the lens and the camera body and if they're anything other than clean and bright then use a clean pencil eraser on them. Be very, very, careful not to let any of the rubber crumbs into the lens or the camera body.
If that fails, visit the Tamron website to see whether the lens can be returned to be updated for other bodies. if it can't then sell it and buy a later Tamron model or better still a Canon one. They may cost more, but the results are better and their resale value is much higher.
1helpful
What should i do?...my tamron 17-50 began to have a fungus.
Well, that's a great lens and most definitely worth the cleaning/service. I don't know where in the world you are but fungus growing inside a lens is only heard of in high humidity environments and can happen fairly quickly. Are you sure this is a fungus on the inside and not just a clouded smear on the front element? If the lens is having a problem then the camera won't be to far behind. To answer your question more directly "what should I do" my suggestion is to send the lens to a authorized Tamron service/repair center/depot for cleaning. After which get a few of those little moisture absorbing packets and place them in with your photo gear to help reduce the moisture.
Hi, I have a canon eos rebel xs. the mirror is kind a dirty, can it be cleaned by me or need to have it cleaned at canon service centers?s I also have a Tamron Telephoto lens, when I do a full zoom in...
This is a digital camera and I suspect it's not the mirror that's showing dirt it's the sensor. If you are seeing small bits of dirt on your pictures then it's dirt on the sensor. I would suggest having it cleaned at a camera store or repair facility if you are not comfortable with doing it yourself. Cleaned improperly can damage the sensor and renter the camera pretty well useless. The dirt inside the Tamron lens I would also suggest cleaning and if you are getting an error message you may as well send the camera in for a complete cleaning. There are kits on the marked to clean the sensors but again if you are not confident that you can do this then sent it to people that can and do it on a regular bases.
Tamron 28-300 lens broken off from camera
Hi: The only way to have this lens serviceable is by having a qualified tech repair the lens mount. You can contact the folks at Tamron's service center and ask for an estimate. Good luck: theboyd
ERROR 99
try cleaning the lens contacts of your lens and camera.
4helpful
Tamron 28-300mm lens disassembly help
Both, But start at the rear to remove the electronics and the outer barrels. Remove any rubber grip to expose 'hidden screws'. I would mark everything or document with pictures during disassembly.
2helpful
2answers
Problem in lens opening
Dear sir
I purchased Kodak EasyShare Digital Camera (5.5 mega pixcel)last year. but now i am facing lens opening problem in my camera.
When we on the camera the green light is blinking but when lens trying to open its became dead.(no red signal)
but i can able to review photos no problem in reviewing.
No problem in battery i tryed all kind of battery but same problem.
Pls. suggest how to slove & if possible pls give the address of authoried kodak service center in pune
Cameras Logo
Top Tamron Cameras Experts
Steven Wander
Steven Wander
Harrie
Are you a Tamron Camera Expert? Answer questions, earn points and help others
