Question about Garmin Nuvi 2595 LMT GPS
My nuvi2595lLM won't turn on
Was on car charger. Came on for a second and went off to black screen. Won't come back on.
Posted by Gary Swanson on
Kenny Rasmussen
    Habit-Forming:
  • Garmin Expert
  • 184 Answers
Garmin support is located in the USA and usually can help. if they cannot fix the device they can offer you a trade in value for that device towards a new one. that is my recommendation.
also, make sure it is fully charged and try a friend or neighbors charger as it may be that your charger has just gone bad and your Garmin is unable to get juice... alternatively plug it into your computer
Posted on Mar 27, 2015
Charles Houlroyd
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
I would try doing a hard reset. On the back of the Garman is a reset button - try pressing it
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Posted on Mar 22, 2015
Simson Ma
    Habit-Forming:
    New Friend:
  • 40 Answers
Defeated. Go to get refund.
Posted on Mar 18, 2015
2answers
My Veon 32'' tv wont turn on
Usually fuse near cord interior in case. Teardown. Careful..VOLTAGE danger even unplugged. Touch nothing else.
M975 won't turn back on
I had the same problem before, it may need to charge but, your charger might be fried from having it plugged in too long... purchase or find a new charger for your product
2answers
I charged my adamant zte and now it won't turn on
Hello Dear:::::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Cdm 8615 battery discharged...cant turn it off
pull battery out for 30 seconds and put back in, it should fix the problem.
here is a lin for u to read in a pdf
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiyyMLbh5nXAhVD22MKHWwEBpwQFggvMAE&url=https%3A%2F%2Fwww.cellcom.com%2Fresources%2Fmedia%2Fdocuments%2FUTSTARCOMcdm-8615-manual-1154.pdf&usg=AOvVaw0DtRprs1wAC6FOsJWHLI54
1helpful
Lg lucid screen went black
Remove your battery, and leave it out for a minute or so, put it all back together, and charge... it may look lie it isn't, but since this phone seems not to have an LED the navigation buttons are your only indicators of trouble(pure speculation).
Your battery is probably depleted. i found out the hard way that a Droid X won't charge it properly... hope this helps
10helpful
4answers
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
My iphone wont turn on at all..I went to bed it was charging and when i woke up it won't even turn on..help...
try to change battery buy a new one plug the charger to phone is phone turned on.?
jibrabjee
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
3answers
Garmin Nuvi 2595 LMT GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
