Question about Home
What are the options to screen printing on t-shirts?
Ronan Miller
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Custom World a high-quality customization service in the UK has become one of the best printing companies among all. Shop online through this website. This provides you with custom t-shirts at a cheaper price. You are also free to customize your design and logo to your things.
Posted on Dec 10, 2019
How do I print attachments embedded in websites using Windows 10?
when you push print, screen will pop up either the option will be where you can see it or if the printer company will put it into options.
your looking for box to put a check mark
the statement says the following statement:
print background colors & images
Oct 07, 2015 | ASUS Computer International Asus...
How do i use the boxed options on certain keys?
Prt SC (Print Screen) does NOT send the screen to the printer!!
If your windows desktop is showing, Print Screen will capture the ENTIRE screen to the clipboard - Open Paint and Ctrl-V to paste the captured image into paint (or other graphics program).
If you want to capture only the active screen, use Alt-Prt Sc and do the same with it.
Take screen capture print your screen Windows Help
Print screen Wikipedia the free encyclopedia
Feb 20, 2015 | Acer Computers & Internet
How do I get my prtscn to print straight
Instructions
  1. Use PrintKey2000 to Direct Print
    • 1Download and save PrintKey2000 or PrintKeyPro from the "Resources" section. Save the file in a folder named "Printkey" on your "C:" drive. Double click the .exe file and follow the onscreen instructions for a problem-free installation.
    • 2 Access the Print Key program by double-clicking the hand icon in the bottom right hand corner of the task bar.
    • 3 Double click the "Options" tab in the upper right hand corner. Click on "Define Hot-keys." Set a hotkey for printing the full desktop and for printing the active screen you are in.
    • 4 Navigate back to the "Options" tab and select "Direct Print (No Dialog)" so that it has a check mark next to it.
    • 5 Select the "Printer Options" function on the main program screen. Select the printer you want the print jobs sent to.
    • 6 Select a screen to use as a test. Press your hotkey for printing the full desktop and then the hotkey to print the active page. You want to make sure both functions work properly.
    Use the Print Screen Function Without a Plug-in Program
    • 7 Press the "Print Screen" key on the keyboard to print the full desktop. Press the "Alt" key plus the "Print Screen" key to print the active window.
    • 8 Click "Start" in the lower left of the taskbar. Navigate to "Applications" and choose the Microsoft Paint program.
    • 9 Click "Edit" in the program screen and click the "Paste" option. You will now see a copy of your screen capture.
    • 10 Navigate to "File" and save the screen capture as a .jpeg file. Navigate to "File" again and click "Print" to send the job to an installed printer.
    Using the Print Key Function with ScreenShot 2 Print
    • 11 Download and install ScreenShot 2 Print. ScreenShot 2 Print has a free trial option, and as of May 2010, costs $7 for the full version. Configure the program to print to a designated printer from the onscreen commands. The screen captures will print automatically when the required keys are pressed.
    • 12 Hold down the "Control" key (Ctrl) and the "Print Screen" key to capture a screen shot of the full desktop. The image will be sent directly to the designated printer.
    • 13 Hold down the "Shift" key and "Print Screen" key to take a screen shot of the active window, which is sent directly to the printer.
May 21, 2014 | Microsoft Computers & Internet
I used to be able to select the draft option when printing, but this seems to have disappeared. I am using an Epson stylus TX100 printer and my document is in Word 7. How do I get draft back?
You can set the option to print in Draft mode while in Word. Follow the steps below and see if it works for you.
1. Go to the MS Office button in Word at the top left of the screen.
2. Then click on Word Options button located to the bottom right of the Office Menu.
3. Select the Advanced Options at the left of the screen.
4. Scroll down and look for the Print Advanced Options
5. Choose "Use Draft Quality"
You can also set your printer's properties to print in Draft mode. If you've tried that and it doesn't work I would suggest updating or reloading your printer's drivers. The print drivers may have become corrupted.
I hope that helps.
Apr 12, 2011 | Office Equipment & Supplies
I replaced my ink cartriges and I'm still have a blurr and fade on documents that I print.
  1. Open your application program.
  2. Select Print from the File menu. A Print window appears.
  3. Make sure EPSON Stylus CX9400Fax Series is selected.
  4. Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
    A printer properties or preferences window appears.
  5. Select the type of document you're printing for the Quality Option setting.
  6. If you want to print borderless photos, click the Borderless checkbox.
  7. Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
  8. Click the Advanced button. The Basic settings change to the Advanced settings.
  9. Make sure the High Speed option is not selected in the Print Options section.
  10. Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
  11. Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
Jan 18, 2010 | Epson Stylus CX9400 Photo Printer
How can i save a scanned pictures on my windows pc
The best option is print screen option.
Press F11 - window becomes full screen
then press print screen
then paste that in to bitmap blank file
then save that with jpg extension
Nov 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Double sided printing
Firstly ensure that the duplex unit is installed by going to start - Settings- Printers and faxes.
Then right click your printer and select properties. Select the last tab at the end of the properties screen which reads "Option"
Then under the options where you see the Duplex unit option select "Installed" from the drop down menu.Click Apply and OK
Alternately you can insert the ip address of the printer and select the gather option information...
Now for double-sided/duplex printing
1. Open the document you want to print eg: MS Word
2. Click on the "file" menu select "Print"
3. Then Select the printer from the drop down menu
4. Click on the "properties" box next to the printer you selected
5. In the first screen on the "Setup" tab find the Binding option and select at the Print type "DOUBLE SIDED"
6. Click apply and this will enable double sided printing.
7. you can leave the binding position on "Auto"
Hope this helps
Regards
Rene Fernandes
Feb 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Basic printing, not photos
Well the paper issue should be resoved by going in through the control panel to get to the printers section where it has a button (once your on the R300's settings) where you can reset all the printer options then after that in the document in the printer settings if you go to the print screen and click the properties button (right next to the name of the printer) when the properties section come up under the quality options it should have five options, one of which is labeled text, click that one and print it should come as a regular document (you might have to re-reset the options in this screen as well before printing the document)
Sep 30, 2008 | Epson Stylus Photo R300 InkJet Printer
Home Logo
621 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
