The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted! IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing. If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay. depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
Friend you can unlock your mobile using the unlocking code & i found the site http://www.unlocking4u.com/siemens-s56/rs6wp9/ .This site provides the unlocking service at cheap price.Visit for more details.
Hi.... Unfortunately there is no unlock code generator for siemens,,, so u have to buy that code...... Refer the site, " http://www.siemens-unlocking.com/Siemens/A56 ". This site will give you the unlock code for your model. There is a Money Back Guarantee too ,if the code doesn't work.... Hope my info is useful..... Bye....
So found the problem it was the seilnoid on the wasnt working properly store said good put it back hit with small hammer fired up so just replaced whole strarter now fires first time sounds awesome had lot of trouble tracking it down went threw new battery's thinking that was prOblem but was bad starter unit try this maybe will help u to
Could either be a faulty SIM card, or SIM contacts on the phone,
or SW conflicts, or battery contacts.
you can try updating the phone software, but it sounds like you need to get the store to replace the phone for you, sounds like a lemon.
Good luck
And please comment back on your phones model, since you posted on the wrong product page ;] thx
