BumbleRide Indie Twin-Spice Jogger Stroller Logo
Posted on Jul 08, 2009
My stroller has a broken axle and broken bracket
My Bumbleride stroller has a broken axle and broken bracket on the handle. Does anyone know where to buy replacement parts?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
452
Points
I called Bumbleride and they sent me a new frame.
Peg Perego Pliko3 Stroller right handle not pulling and allowing collapse
Hi Micky
We would recommend you contact Peg Perego for assistance.
Peg Perego Customer Service
Mar 01, 2014 • Baby Gear
Quinny zapp xtra black handle bar broken so can't lay baby back
Hi
No the grey recline / remove button on the back of the Zapp Xtra seat unit cannot be repaired. It would be a case of replacing the seat unit.
12helpful
How do you open a bugaboo frog pram stroller
To open the Frog, follow the steps below:
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle out with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
2helpful
2answers
How do I collapse bugaboo stroller
take off the basinette or seat
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
5helpful
4answers
Pacific Explorer Bike Trailer/Jogger Stroller
it's kinda tricky to put the bracket on, but it should have come with a weird bracket that kinda looks like a brake caliper, the bracket goes around the back of your frame, as opposed to attaching to the wheel pin like the inStep trailers...if you don't have the bracket, i dont know what you can do
1helpful
Bugaboo Gecko Collasped Chassis won't open.
To open the Gecko, follow the steps below:
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle outwards with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
2answers
Difficulty turning my bumbleride rocket when wheel is locked.
The only thing you can do is to always have the foot rest up instead of down so your child won't be able to reach it,that's what I did.
1helpful
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Top BumbleRide Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a BumbleRide Baby Gear Expert? Answer questions, earn points and help others
