Microwave Ovens Logo
T
Tom McGibbon Posted on Feb 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model # MWG9115SL Suffix D microwave how to change the light bulb?
Ruth summersides
Level 3:
Genius:
  • Master 1,493 Answers
  • Posted on Feb 18, 2015
Ruth summersides
Master
Level 3:
Genius:
Answers
1493
Questions
Helped
363067
Points
2425
Check manual, or contact manufacturer
2answers
PT7800SH7 microwave... how do I replace the bulb in the microwave?
There are video's on YouTube how to change the light bulb in a microwave.
1helpful
How can i get a manual for a emerson model #MWG9115SL SUFFIX F?
I suspect that the manual is the same for the MWG9115SL F and other suffix models. The manual for the MWG9115SL is available from the Emerson Radio Corp. customer support page: http://www.emersonradio.com/owner_manuals.php . The direct link is http://www.emersonradio.com/resources/owner_manuals/manual_1325712698.pdf .
I hope this helps.
1helpful
Emerson microwave oven with grill mwg9115sl
You need to remove the top cover and the light could be seen mounted on the side of the cabin. You can access this by removing the guard and the bulb can be replaced with the same type rating. If the bulb has not fused then check on the door switch and power from the board.
I need a manual for the MWG9115sl
Many Emerson microwave owner's manuals are available for free download here.
Your specific manual is here.
Emerson support is here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer..
How do I change the light bulb in a JES 1451 ?
On this model, it's not meant to be a user serviceable part.
You would have to remove the outer cover, and then the light bulb is located on the air duct attached to the magnetron on the right side of the innards.
You can find helpful exploded views and order the bulb assembly from the Pros here.
Enter your full model number from the tag with suffix and no spaces.
See these help files on safety and disassembly first.
No instructions in the manual on how to use the grill feature. The model is MWG9115SL. Where can instructions for grilling be found. The manual that came with the oven does not give enough information such...
Hi and welcome to FixYa I am Kelly
I found it here:
http://www.emersonradio.com/owners/MWO%20manual/MWG9115SL%20Owner's%20Manual--%20(Eng).pdf
and here:
http://kitchen.manualsonline.com/support/emerson/microwave-oven/microwave-manuel-2078077
Click on the green link anonymous user submitted manual
These are the only manuals I know of. I did download the manual using the 2nd link and cooking times start on page 22 of the pdf file.
Thanks for choosing FixYa,
Kelly
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
2answers
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
