Question about Frigidaire Dishwashers
Hold to lock button how to unlock manual no good
The hold to lock button how to unlock
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, friend!
I see that you are having trouble with the control lock feature on your Frigidaire dishwasher. I would be happy to assist you with unlocking the dishwasher. In order to provide you accurate assistance I would need your model number. You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. I look forward to helping you out. -Matt
Posted on Feb 18, 2015
How would I lock and unlock the mp3 player. I have the Coby MP610-4G player.
The power switch on the side doubles as the lock. Slide it down (away from the "HOLD" position) to unlock it.
Jan 22, 2011 | Coby MP-610 MP3 Player
Tip
Viewsonic monitor Lock and Unlock instructions
OSD and Power Lock Settings
OSD Lock: Press and hold [1] and the up arrow UP for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
OSD Unlock: Press and hold [1] and the up arrow UP again for 10 seconds.
Power Button Lock: Press and hold [1] and the down arrow DOWN for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display?s power will automatically
turn ON when power is restored.
Power Button Unlock: Press and hold [1] and the down arrow DOWN again for 10 seconds.
May not work on ALL Viewsonics
http://www.viewsonic.com/assets/027/7939.pdf
Service manuals: http://ftpkuban.com/FTP/Manual/ViewSonic/
on Apr 14, 2010 | Computers & Internet
Hello there top of the morning to you! First of all I just bought a 2000 Audi TT 1.8T yesterday and didn't realize a few things till i brought her home from the dealer. The key fob needed new batteries so...
once you fitted new batteries to both fobs you needed to reset the car.....put key in drivers door and unlock/hold key over(windows go down)wait 30 secs then lock/hold over key,(windows go up)wait 30 secs,then press/hold unlock button for 30 secs.you have just reset the system.you have loads of other little gizmos but i will leave you to find them all good hunting....one side parking lights/driveway illumination/and more.
geoff
Sep 10, 2010 | Audi TT Cars & Trucks
What to do to unblock osd lockout
You can download user manual here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
See Page 54:
? OSD Lock — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message "OSD Lock" displays for 10 seconds. ?If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD. ?If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Please leave good rating, thanks.
Mar 31, 2010 | HP vs15 15"LCD Flat Panel Monitor
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
I have a GE 6.0 cordless ho do I unlock it?
I just did the same thing. Press and hold the # button until you hear a beep....this should unlock the keypad and the lock sign will disappear. Its a good function to have when you have kids around.....they cannot dialout except 911 but you can still ake incoming calls.
Jul 01, 2009 | Uniden Cordless Phone
How do i program a new remote for my 2001 chevrolet blazer?
You may program up to 4 transmitters, using following procedure:
Transmitter Programming Procedure (No Tools Required)
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation
May 06, 2009 | 2001 Chevrolet Blazer
I'm looking for instructions on how to program the keyless remote
HOLD TO UNLOCK BUTTON ON YOUR DRIVERS DOOR, WHILE HOLDING BUTTON DOWN TURN KEY ON, OFF, ON OFF, ON OFF, YOUR DOOR LOCKS SHOULD CYCLE,. LET GO OF THE UNLOCK BUTTON. HOLD DOWN LOCK AND UNLOCK BUTTONS ON YOUR REMOTE AT THE SAME. IT WILL TAKE ABOUT 1 MIN AND YOUR DOOR LOCKS WILL CYCLE AGAIN. IF YOU HAVE MORE THAN ONE REMOTE, HOLD DOWN LOCK AND UNLOCK ON THAT REMOTE AFTER FIRST REMOTE IS PROGRAMMED. ONE AT A TIME. TURN VEHICLE ON AND TURN BACK OFF. YOUR REMOTES SHOULD WORK. GOOD PLACE TO HOLD YOUR REMOTES IS CLOSE TO IGN. CYLINDER SWITCH
May 04, 2009 | 1995 GMC Jimmy
Samsung vr3607 vcr is locked
following is pasted from SV-7000W manual: 1 To lock the VCR, hold down the P/STILL (II) button for approximately five seconds. Result: The lock indicator (LOCK) is displayed. If a cassette is in the VCR when you lock it, the cassette will first be ejected. 2 To unlock the VCR, hold down the P/STILL (II) button again for approximately five seconds. Result: The lock indicator (LOCK) is no longer displayed. If that fails, try the same thing using the play/stop button. Cheers
Nov 13, 2005 | Samsung VR3607 VHS VCR
Dishwashers Logo
167 people viewed this question
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
