Question about Furniture
I'm replacing my starter relay, 3012-5a A1G7 Cubigel SA and overload and forgot which lead to connect it to.
The starter relay has three connector lugs 2 on one side and 1 on the opposite side.
Posted by Dale Nunn on
  • 5 more comments
  • Carl Hero
    Carl Hero Mar 29, 2015
    Dale,
  • Carl Hero
    searches indicated that the relay should rattle if they're defective but this one does not; did you find that the relay was in fact faulty ?
  • Carl Hero
    Thanks for your help.
  • Dale Nunn
    Dale Nunn Mar 29, 2015
    Mine didn't rattle. I measured across the disc and couldn't get a reading. I think the biggest problem was the power relay. when I opened it there was alot o
  • Dale Nunn
    of arcing and burn marks
  • Dale Nunn
    I bought the panasonic power relay from Amazon.com
  • Tom Cepernich
    Tom Cepernich Apr 02, 2018
    I need the exact same relay. You found it on Amazon?
Carl Hero
    New Friend:
Dale,
Did you fine a fix to your problem & where did you find this replacement part ?
I have an Everstar HDWC35 wine fridge with maybe a faulty relay.
Thanks,
Carl
Posted on Mar 28, 2015
Testimonial: "Yes I did. I bought the 1858460700 Starting Relay $15.00 1858450900 Overload $10.00 at FixIce.com I also replaced the power relay on the control board. PANASONIC EW JW1AFSN-DC12V-F POWER RELAY SPST-NO 12VDC, 10A, PC BOARD Easy to replace only four solder connections. The panasonic power relay can handle a little more current than the original relay. Good luck if you have any questions let me know..."
  • 3 more comments
  • Carl Hero
    Dale, I found the Panasonic power relay on Amazon; is that part locaten in the door & if so do you have a tip on how to remove the door seal ? Thanks again for your help.
  • Carl Hero
    Carl Hero Apr 08, 2015
    Dale,
  • Carl Hero
    Dale, got the relay & Overload installed-it purrs like a kitten now but it's not cooling. Can you tell me what to try next / Thanks
  • Dale Nunn
    Dale Nunn Apr 08, 2015
    Did you replace both relays? When you say it's purring like a kitten does that mean that you can tell the compressor is running? Because if the compressor is running you should be cooling. Did you set the temp to 46 degrees?
  • Dale Nunn
    How long has it been running?
n36601
  • 3 Answers
Dale:
I'm currently researching a related question and found this image. It may be what you need.
Dennis
I'm replacing my starter relay, 3012-5a A1G7 Cubig - 7d059e76-1694-411f-96d2-7c1c86285d2a.jpg
Posted on Feb 25, 2015
Testimonial: "Thanks but I'm looking for a unit that only has two leads not four."
Please help to find this part 3012-5a A1G7 Cubigel SA
I don't think that is a good part number, but you can try to Google it.
Sep 02, 2015 | Audio Players & Recorders
How to replcae the starter
o remove:Disconnect battery negative lead.Disconnect positive lead and connector of starter relay.
Remove three fixing bolts from starter motor. Top bolt also holds the cable support.Slide starter motor to rear, turn and lift upwards.To reinstall:Transfer locating bush to new starter motor.
Reinstall in reverse order.Torque bolts to 50nm.
Oct 06, 2011 | Cars & Trucks
I need a wiring diagram for my 1975 iron head harley. Especially from relay to seliniod
I think I can help with the wiring diagram. Contact me directly at [email protected] The earliest drawing that I have is for a 1979 model but it can be used.
You starter relay has three connections on it. Usually two large connections and one smaller. One large connection is the hot wire from the main breaker or battery. The other large connection goes to the small connector starter solenoid. The small connector on the starter relay is from the starter button.
On the starter solenoid, the positive battery cable goes to the solenoid long connector. The cable to the starter comes off the shorter large connector. The small connector has the wire from the starter relay.
I hope this helps, if not, drop me a line directly. Good Luck
Feb 08, 2010 | Harley Davidson XLH 1000 Sportster...
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Refrigerator Model #KSRA25ILSS03. How much and how difficult is it to replace a starter relay?
a 3 in one start relay usually runs about $75 and it is not that difficult to replace if you are sure that this is the problem there is also the chance that the compressor could be damaged. you do not want to replace just the relay as there is also an overload circuit the 3 in 1 starters have everything in it and good instructions as far as which wire goes where you have 2 wires for 120 volt in and then three connection on the compressor
May 15, 2009 | KitchenAid Refrigerators
Compressor clicking on and off fridge now warm
looked up your model number and got a part number of 8201799. is that the number you got??? cause in the pic it looks like there are 3 terminals on the relay(brown piece) there should have also been instructions in the package no???
Mar 28, 2008 | Refrigerators
Furniture Logo
5,056 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
