Question about SIM2 Office Equipment & Supplies
Sim2 domino 30h lamp life reset
Replaced lamp. will power up for 10-15 seconds, great pic, then lamp shuts off. I need the lamp life reset procedure for SIM2 Domino 30BS-H
Posted by Frank Fulton on
  • Frank Fulton
    Frank Fulton Feb 16, 2015
    I found the info, reset the lamp meter, however, it still is turning off the lamp after 30 seconds? Another Issue???
2 Related Answers
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: sim2 domino 20
Hi there
I checked the manual of your Sim2 , but they don't even mention the lamp in there.
You already have the front cover off , check if you can see any small screw around the lamp housing. They normally attach the lamp's housing with tiny screws to the rest of the unit.
Posted on Apr 24, 2008
Anonymous
  • 130 Answers
SOURCE: My Sim2 Domino 30H has reverted to factory settings: looks bad!!!
uninstall all of it,then reinstall,hope this helps
Posted on Dec 30, 2009
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
May 20, 2014 | SIM2 Office Equipment & Supplies
Tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
Be sure the power cord is plugged into a properly grounded wall outlet.
Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the
PIP or SPLIT button on the remote control at same time for more than 5 seconds.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 | Televison & Video
How do you reset the lamp timer on a Sim2 Domino 60.
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
Mar 16, 2011 | SIM2 DOMINO D80 DLP Projector
Sony kdf-46e3000 turns on stays on for a few minutes shuts off green power light flashes then goes to red flashing lamp light hit the power button again process starts all over. Picture looks great for the...
It is the lamp that is reached at end of life span.
Replace lamp in tv if it has not been replaced in last 2-3 years.
Lamp replacement procedure is easy and written in user manual.
Aug 14, 2010 | Sony KDF46E3000 46" Television
Power LED stays red - does not want to turn on
hi maybe I am very late for this, but do you still have the SIM2 D10?
I need some part if of course you have it and it still broken.
Thank you for your reply
Jan 20, 2010 | SIM2 Domino D10 Home Theater Projector...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sim2 domino 20
Hi there
Apr 24, 2008 | SIM2 Domino 20 Multimedia Projector
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
197 people viewed this question
Top SIM2 Office Equipment & Supplies Experts
Marvin
Marvin
Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
