Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
Posted on Sep 23, 2009
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Posted on Jan 26, 2010
SOURCE: Looking for sewing machine manual for singer
I went to the singer website & typed the number in 6218 & it came up with nothing, is that the correct model number?
the tension problem try adjusting the top thread tension to 3-5, & see if that helps the loose tension
Posted on Oct 21, 2010
