Question about Mustek PF-A722BM PFA722BM Digital Photo Frame
On my Mustek PF-A722BM digital photo frame the image is broken vertically by a white horizontal bar. Is there a way to fix this? Image appears complete but with the bar inserted in the middle of the s
White bar is exactly in the middle of the screen, running from the (short) edge to edge (left to right in horizontal orientation). It appears to be inserted into the image because the image is complete on either side of the white bar. The bar is present regardless of the images.
Posted by Shawn Buchanan on
3 Related Answers
HarryHarley
Harry
  • 343 Answers
SOURCE: can a sdhc card work on a mustek pf-b800?
Only your manual can tell you that. Find out what card is compatible AND make sure you format it first using your digital photo frame settings software. You manual will tell you how to do that.
Always works better that way.
Posted on Dec 22, 2009
SOURCE: mustek 1248ub image is not clear
Hi
You clean this scanner all mirror by soft cloth.When this mirror is dirty then all emage are not clear,so you need clean it.If you are a technician open your scanner Platen glass very carefully and clean all mirror then fix it.
Posted on Dec 27, 2009
Anonymous
SOURCE: PF-A700B Digital Picture Frame: Hi i have a Mustek PF-A702B digital photo frame an...
have you tried formating your SD card to FAT32 format?
Posted on Jun 19, 2010
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture...
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Jan 26, 2011 | Canon PowerShot A470 Digital Camera
Some of my vertical (portrait) photos on my 15" are displaying as horizontal (Landscape). What can I do to fix this?
Have you saved the images that are appearing as Landscape in Portrait?
The frame should display the images as you saved them. Rotate the image in your photo editing program until they appear as Portrait, then save them. This should fix your problem.
Sep 26, 2010 | Sunpak (SDPF-070AW-0US) Digital Picture...
Can a sdhc card work on a mustek pf-b800?
Dec 22, 2009 | Mustek Pf T80B 8 Inch Digital Picture...
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
5400 Digital Camera
image sensor failure, contact nikon for free service
Jan 16, 2008 | Nikon Coolpix 5400 Digital Camera
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Mustek PF-A722BM PFA722BM Digital Photo Frame Logo
74 people viewed this question
Top Mustek Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
