Question about Toshiba Satellite M35X-S149 Notebook
When I turn on laptop, fan starts up runs 3 seconds and shuts down and no startup.
Posted by ef256 on
Alex Smallwood
  • 144 Answers
Hi
Please Sign Up At My Forum Below For A Quicker Response To All Hardware & Software Related
Computer Problems And Troubleshooting. We Can Also Help You With Upgrade Decisions And Bios
Modding/Unlocking.
Sign Up Free Today At www.biosmods.com!
Posted on Jul 08, 2009
My netbook fan spin just for a second and then shuts down
Is the netbook functioning otherwise? Fans often spin on startup, then turn off until they are needed.
Feb 05, 2014 | Computers & Internet
Latitude D830 starts then shuts down quickly.
1. Make sure you are plugged into A/C.. Your battery could be running low.
2. Make sure there is nothing blocking the heat vents. This symptom is typical for overheating processors.
Mar 17, 2013 | Dell Latitude D830 Laptop Computer PC...
Fan startup
Have you cleaned the fan, vents, etc? You didn't supply the Make, model of laptop or the OS you are using?
Jan 28, 2013 | Computers & Internet
Fan shuts off on computer startup, led lights are
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
Nov 30, 2009 | HP Pavilion dv6000z Notebook
Projector turns off after 15 or so seconds of startup. The dell logo displays for those 15 or so seconds and roughly 1 second before it turns off, it projects a dialog box. It will shut off much faster if...
The problem you're describing is a classic symptom of a defective fan--some fans simply have + and - power connections. However, other fans have a third, yellow wire, for sending a pulse to the main board to tell it that the fan is indeed running. If the main board doesn't get the signal, it's internal programming instructions perform a shutdown in case of any error condition--protects the unit against excessive heat, current draw, etc. MAKE SURE THE DUST FILTER IS CLEAN! A dirty filter causes the fan to pull harder, increasing current draw, possibly triggering the symptom. The other possibility is a defective power supply causing an over-current condition. Again, the main board senses this and cues a shutdown. You'll need to send the unit out to a repair facility to confirm a diagnosis. Any reputable shop will give you a quote first with an explanation of the problem.
Sep 16, 2009 | Dell 3400MP Multimedia Projector
Laptop keeps shutting down, both fans not working
sounds like you have a bad motherboard, or uP...is this under warranty, by chance?
May 25, 2008 | Dell Latitude C640 Notebook
Toshiba equim
hi,i asume that ur laptop runs for sometime in the fresh start, then it shuts down....check for the CPU temprature, the fan RPM must be low , not sufficient to cool down the CPU, give it a try,, secondly even the RAM can cause this problem,, go step by step to eliminate the culprit.. let me know
Dec 06, 2007 | IBM ThinkPad T41 Notebook
Toshiba Satellite M35X-S149 Notebook Logo
161 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
