Music Logo
A
Anonymous Posted on Feb 16, 2015
Roland RD 300GX service manuel - Roland Music
rhodesworks
Level 3:
Top Expert:
  • Roland Master 3,159 Answers
  • Posted on Feb 17, 2015
rhodesworks
Roland Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
562330
Points
331463
How do I find a new motherboard for this?
Contact Roland customer service. You might also want to try Roland Canada.
300GX. How do I reinitialize?
The instructions are on page 77 of the manual, which is located here-
http://lib.roland.co.jp/support/en/manuals/res/1810808/RD-300GX_e2.pdf
1helpful
Breaking Roland RD 600 hammers
The Roland RD-600 is a digital piano, and its hammer action mechanism is designed to simulate the feel of an acoustic piano. The hammers in digital pianos like the RD-600 are typically made of materials like plastic or a combination of materials to replicate the weighted feel of acoustic piano keys.
The breaking of hammers in a digital piano is not a common issue, and it's not typically related to the age of the instrument alone. Several factors could contribute to the breakage of hammers, and it's essential to consider the following possibilities:
  1. Excessive Force: If the keys are played with excessive force or if there's any physical damage to the instrument, it could lead to the breakage of hammers.
  2. Material Quality: The quality of materials used in the construction of the hammers can impact their durability. If the hammers are made from subpar materials, they may be more prone to breaking.
  3. Manufacturing Defects: In some cases, there could be manufacturing defects that make the hammers more susceptible to breakage.
  4. Maintenance: Lack of proper maintenance, such as cleaning and regular inspection, may contribute to the wear and tear of components, including hammers.
If you've observed a pattern of hammers breaking with regularity, it might be worth investigating the specific cause. If it's due to excessive force or physical damage, adjusting playing habits and taking care during transport can help mitigate the issue.
As for whether it's worth purchasing new hammers from Roland, it depends on the extent of the damage and the overall condition of the instrument. If the RD-600 is in good condition otherwise and you enjoy playing it, replacing the hammers could be a reasonable option. However, you may want to assess the cost of replacement hammers compared to the overall value of the instrument, factoring in the cost of a used RD-600 and any potential future maintenance needs.
Jan 24, 2018 • Music
1helpful
My Roland Rd-500 has no sound....the factory demo
You either did not get the ribbon cable seated OR got it upside down.
If this cable is the flat ribbon with exposed solder plated points of contact, OFTEN those connectors have a latch to release by GENTLY moving tabs on eaither side in the direction of pulling the cable out. This lock MUST be moved out slightly to allow the cable to seat properly. The solder plated contacts will be FULLY into the connector when seated properly.
These cables ALSO can be inserted backwards and NO connection will be made.
2helpful
2answers
Where do I get spare parts for my Roland rd 300s. Thanks
It depends what parts. Mechanical things and special chiops you need to contact Roland support parts dept. Go to Roland site and go to support.
For common electronic parts, go to DigiKey.com or Mouser,com.
Feb 11, 2010 • Music
1helpful
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 • Music
Transpose feature
Here is the ROLAND website. I am afraid that you have to give you e-mail to go further.
http://backstage.rolandus.com/login.php
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
