Question about RTO 50cc Moped Scooter
I put 6g rollers in my 80cc vip scooter. now I can barely start it an while I am riding it wont stop revving even with the throttle turned back. it was very difficult to stop and dangerous as well. please help.
Posted by kevin gaska on
1 Related Answer
Randy Ohler
  • 14585 Answers
SOURCE: How do I stop my rear brakes from squeezing? I've watched the video and adjusted them to no avail. When I ride and let off the gas it's like something is holding the scooter back.
Most likely there is something sticking. You seem to be wanting to work on it..buy the manual.. You are on a car site. Not mopeds. I can and do fix them. But you wouldn't pay me the diagnoses to fix yours. Most people don't.
Posted on Aug 28, 2015
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
Why doeas my 50cc vip scooter keep revving even when giving no throttle. it is also very hard to start.
Check your ?il seals to crankshaft and freewheeling of the sting of the carburetor and gaskets to it.
Feb 16, 2015 | Motorcycles
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
Why has my Lambretta UNO 50 lost power, and why does it keep dying or struggling when I try to ride it?
A tip with air flow screw or mixture screw as I call it,is screw in all the way just so its snug not tight then count one an a half rotations back out and that's roughly pretty wow right, then listen to the exhaust note when revving up and down then you slightly a just the screw in or out un till you here a sweet spot in the acceleration and that's it to easy.cya Neil
Jul 12, 2014 | 2008 Lambretta Uno 50
Rascal Scooter model 245
If the throttle is stuck a little bit then it may not let you start it while the throttle is on
Apr 13, 2014 | Health & Beauty
Engine revving itself
Sounds like you have a vacuum leak .check the vacuum hose that goes onto the throttle body
Jul 27, 2013 | 2004 Opel Zafira 2.0
Problems with linhai 80cc quad
Battery or battery cable connections. After you get it running make sure the charging system is working. Maybe riding it ran the battery dead from it not charging properly.
Feb 11, 2012 | Linhai People 250 Motorcycles
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Scooter wont start
carb could be clogged with trash even though fuel is gettin to carb the main jet could be blocked not letting fuel enter intake
Aug 02, 2009 | 2004 Sym Husky 125
RTO 50cc Moped Scooter Logo
54 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
