I had a problem similar the water flow was good but still coded E90 after 9 sec. I put a magnet next to the water flow sensor. Finally after a long time trying to diagnosing the problem this finally worked
I taped a magnet to it and put it he base back together. Been over a week now and it's still working!
Have you cleaned filter? Before you do all this, dirty filter creates a code 90, so clean it if you didn't.
SOURCE: I cannot get the pump to pump water, motor still works.
Sounds like air has gotten into the pump and froze the pump. It will need to be replaced due to that reason. You can get a repair kit for the pump but it will not be gaurenteed to work
SOURCE: Intex Deluxe Saltwater System & Filter Pump
Check to be sure the filter and baskets are clean, as you need proper water presure to have unit run.
