Question about Amana Washing Machines
My amana front load washer shakes when it is in spin cycle but I ran a spin only cycle and there was no shaking or loud noise. Why does my washer only shake and make loud noise when there are clothes
I'm only washing half loads of laundry, and the washer is leveled.
Posted by jesinia Rogers on
jalal
    Habit-Forming:
  • 178 Answers
The reason then is the drum dampers.
Posted on May 11, 2015
Gerry Harvey
    Genius:
  • Amana Master
  • 1,481 Answers
Could be a bearing or simply machine not level , check re level the machine so its flat on the floor..
Posted on Feb 16, 2015
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Loud shaking in the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Very loud shaking during spin cycle
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
Sep 16, 2009 | Maytag MAH8700A Front Load Washer
LOUD BANGING AND SCRATCHING NOISE ON SPIN CYCLE
Urgent stop using it !!!!
The drum suspension is coming to bits , get someone in to look at it before the drum comes through the side of the machine
Jun 16, 2009 | Frigidaire GLTF1670A Front Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
314 people viewed this question
Top Amana Washing Machines Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
