I have new 4TB HDD and need to Install Windows 8.1 Pro with an Original DVD but it gives error.
Thanks guy! It's helpful! And friends you can also get your windows 8.1 upgraded from https://www.facebook.com/Windows-XP-Key-1742549319367506 It's convenient and easy to finish the upgrade process with this site.
SOURCE: hard drive
what is the problem when windows 39 minutes setup does not run after setup is copying files setup
SOURCE: Installation
The hard drive will automatically install you do not need to install a driver. I'm guessing this is a hard drive in addition to the hard drive that vista is running on? If so you probably need to format the hard drive to gain access to it. Click the windows button, and in the search field type compmgmt.msc and hit enter. Click continue when the UAC pops up. Now inside the Computer Management Console find and click on Storage and then Disk Management. On the bottom portion look for your new hard drive. Most likely it will have a black colored stripe and say UNALLOCATED. This will explain how to do the rest Yes that article is for XP but the one in Vista is pretty much the same.
SOURCE: Expand Partition of Hard Drive
My advice is start fresh with a new hard drive, install XP on it, then use partitioning software while running XP to create an NTFS partition on the remaining space of your old hard drive if you must keep your FAT32 partition.
An alternate method would be go to the manufacturer of your hard drive and download their partitioning software. Often it will run from a floppy or boot cd and you can partition as you like using it. Keep in mind, repartitioning a drive, especially an older one, has a bad habit of making the old existing data unreadable if you're not experienced so make sure you have a back up.
SOURCE: 2.5'' external fell down
Sorry, but if your hard disk fell down and now isn't regognized by the computer the most possible situation is that the disk is destroyed.
Stelios.
SOURCE: Is it possible to boot from an Iomega eGo
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
Hi baidrk, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Like what cpt, has new drive been initiated and formatted, what error, etc?
