Reattaching the blender and juicer. Watching a utube video to see the correct way to install and retry. Tried different attachments and any that require the arm to be swivelled will not work.
SOURCE: kenwood chef excel attaching blender
http://www.kitchenmanuals.com/manuals/mfg/kenwood/km300_km400_km600_km800.html
hers the manaul for u rate me as fix ya ok its a pdf file also thx nick use adobe reader to view it 43 pages thx agian for using fix ya
SOURCE: Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
SOURCE: blender attachment stuck on
As far as locking the gearhead, no, at least not without taking the planetary off of the mixer shaft. You would have to take the chrome ring loose by prying down gently, and there is a pin holding the planetary to the shaft, a punch would need to be used to drive it out, then you should be able to work it off the shaft and make the whole planetary easier to work on. The only other thing you could do would be to use a penetrant spray, wd-40 or something similar, let it settle into the attachment area, and try some more, sometimes it just takes time, and repeated application to free up.
SOURCE: Need to replace cord on vintage Sunbeam Mixmaster Junior
For mixmaster junior, but should be relevent to many old sunbeams:
That's not the power cord going to the speed switch. You don't need to get those screws off.
To replace the cord:
Cut the old power cord near where it enters the blender.
remove the two front screws, pull off front housing.
remove 1/4" nuts found in recesses of exposed front plate.
pull speed handle out far enough to get a screwdriver under exposed front plate, and pry gently. It'll come off as it's a friction fit.
cooling fan blade is now visible, you need to remove it.
pry up gently on the teeth attaching it to the motor shaft.
Work your way around the 4 sets of teeth, it'll come off. Don't lose the two washers.
unscrew the electrical contacts.
take off the speednuts holding the brush assembly in place.
gently pull up on the brush assembly with a needle nose, until it comes out.
now remove the screws holding the motor coils in place. They're the same ones the speednuts attached to, and have hex heads you can get at with a needlenose.
once those are out, pull on the motor coils gentle, and wiggle them out of the housing.
You'll see the stub of the old power cord at the back of it.
Get a round replacement wire of the right diameter, thread it through the cord hole in the blender, and connect it up to the coils.
-I had to drill the power cord hole 1/16" larger than it was to get a modern cord to fit through it.
On the stub of the old cord, you'll see a metal ring which serves to anchor the cord in blender body. remove it (screwdriver + needlenose and pry), and attach to new cord at the righ position.
Put everything back together, being careful not to bust the carbon brushes.
Congrats, you now have a functional blender with a cord that won't try to electrocute you.
SOURCE: My Cuisinart stand mixer won't
It sounds Motor Control Board got problem as you hear relay click but motor does not get power to rotate from motor control board.
It is electronic hardware failure issue, its not user level repair and professional can do it.
Click Cuisinart Contact link to find out nearest repair center in your area.
Hope these info will help you.
Thanks.
