Check the Advanced tab of the N300's Firewall settings to see if VPN passthrough is enabled. If it's not, the firewall will cut off VPN communications.
You may also need to run the VPN Wizard on the N300.
Here's the manual:
http://cache-www.belkin.com/support/dl/F9K1004v1%20manual%20-%20revA00.pdf
SOURCE: connection problems
Your query "is there anyway...remove...wireless network connections 1-8 ...solely on 3?"
In your Device Manager, delete all instances of the wireless network connection except # 3.
However in WinXP, the default setting of the Device Manager is to hide certain devices (like printers, non plug & play devices and removable devices not currently installed/connected).
In your Device Manager, pls click on "View", check "Show Hidden Devices." Thus enabled, all hidden devices (whether multiple or not) will now be displayed.
Hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
SOURCE: Belkin wireless connection
scott:
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Try going to the usb and the wireless adapter in device manager, properties. And make sure that the computer does not shut them off to save power.
Please let me know how you make out.
thanks
SOURCE: Wireless router does not connect to the internet
try to check if the ip of modem is the same as of router , if so change router , example : if both work on 192.168.1.1 than change router to 192,168.3.1 this might solve the problem , it did for me .
SOURCE: I recently got a linksys
try to uninstall Linksys software then reinstall with the wireless usb connected to computer.
SOURCE: My Wireless adapter connects without
Contact your ISP provider.
There is a great article at Working with Windows Wireless Networks
If you need more help post back!
Thumbs and testimonial are welcome!
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
You must have an active Internet connection for a VPN connection to work.
If your modem is external, make sure that the modem power is turned on.
Contact your network administrator to make sure
that you have the appropriate connection and domain permissions on the
remote access server.
This could be a certificate problem. For assistance, contact your network administrator.
A VPN connection won't work with an active
Winsock proxy client. Contact your network administrator to make sure
the Winsock proxy client is not enabled.
If you know the IP address (for example:
131.107.10.25) of a website, type that address in the address bar of
your web browser and press Enter. If this works, there is probably a
Domain Name System (DNS) resolution problem. For assistance, contact
If you have special software that's required or
installed by your workplace, it could be part of the problem. For
131.107.10.25) of your VPN server, type that address for the VPN
connection, and then press Enter. If this works, there is probably a DNS
resolution problem. For assistance, contact your network administrator.
There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you
see a message that says "The local computer does not support encryption"
and has the error code 741, it's possible that the encryption that your
computer uses doesn't match the encryption used by the VPN server. To
change the encryption settings so that your computer uses the
recommended setting of 3DES, follow these steps:
Open Connect to a Network by clicking the network icon ( or ) in the notification area.
Right-click the VPN connection, and then click Properties.
Click the Security tab.
Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
Click the VPN connection, and then click Connect to try connecting again.
