Question about Samsung 60" 6300 Series Full HD Smart LED TV
How do you remove a stand from the 60" Samsung TV
1 Related Answer
Anonymous
SOURCE: removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Posted on Jan 08, 2009
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
Nov 10, 2017 | Samsung Televison & Video
LG 24MA31D tv base stand removal
Please refer to the user manual instruction to remove the screws and parts of the stand one by one.
Jun 22, 2014 | LG 24MA31D-PU 24" LED TV 1366x768, 60 Hz,...
Samsung t24b350nd how to remove stand
should have a couple of screws holing stand in place. remove screws then lift tv off of stand
Feb 13, 2013 | Samsung T24B350ND 24" LED Monitor
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Removing tv stand
Dec 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung
On the back of the tv at the top of the stand will be four silver screws, remove those with the set laying on it's face or the tv may fall over. after those are removed the stand will slide out of the bottom of the tv. Hope this helps.
Mar 11, 2008 | Samsung LTM1755 17 in. HD-Ready LCD...
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung 60" 6300 Series Full HD Smart LED TV Logo
363 people viewed this question
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
