How do I check and see if pump is out on kenmore diswasher 665.Will pump out but not wash
Get a current monitor or meter (the Kill-a-Watt meters available at Fry's Electronics and eBay for about $20 to $25 is a good easy-to-use current-monitoring tool) and connect it to your dishwasher. Turn it on and start a cycle. After the dishwasher fills, the main pump should run. Watch the current. If it jumps up to a few amps (even briefly), then current is going to the pump and it's not running. If you don't see any increase in current, then it's probably your controller. (The drain pump is a separate pump from the main wash pump, so it can work and the main pump may not.)
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
