Question about Emerson Refrigerators
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
Posted by Mark Palmer on
Larry Nelke
  • 3 Answers
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
Posted on Feb 16, 2015
Dryer starts up runs for a second and stops a few minutes later starts up runs a second or two and stops
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 05, 2014 | Amana Dryers
Karcher 2.91 model
Sounds like motor is burnt out. Needs replacing.
Jan 18, 2018 | Garden
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Mazda rx8 flooded .brakedown come tried to start engine turned over !then starter got hot ,now dosnt turn over just clicks? any wdvice please
Your problem is common in the RX-8. It occurs when you start a cold engine and shut it off before it reaches normal operating temperature. If your car does flood, you can first try depressing the accelerator completely and holding it (which shuts off the fuel pump) and then crank the motor for about 10 seconds (not longer or you may damage your starter). If this procedure above does not work, here is the technique a Mazda dealership will normally use (to be performed at your own risk): 1. Use jumper cables to connect to another car battery. 2. Unplug Air pump connector (the black circular motor housing to the left of the oil filler cap) 3. Take fuel pump fuse out (number 22, a 20 amp, 3 from the top of the second column of the fuse box 4. Crank for 4 seconds, pause for 2 seconds, repeat for about a minute 5. Leave for a minute 6. Crank for 4 seconds, pause for 2 seconds, repeat for about a minute 7. Put fuel pump fuse back in 8. Crank for up to 10 seconds, if it catches but doesn?t start, stop cranking 9. If not started go back to step 3 10. If started, wait 30 seconds for oil pressure to rise 11. Stand on throttle until white smoke stops coming out of the exhaust 12. Disconnect jump leads 13. Leave to warm up on idle for a few minutes 14. Put air pump connector back on (see note 3) 15. Go for a nice long drive to recharge the battery
Dec 27, 2009 | 2004 Mazda RX-8
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
Aug 30, 2009 | Coleman Mach III Air Conditioner
Motor keeps shutting off
It's a problem very common on this brand of refrigarators that the compresor relay goes bad and needs to be replaced(located on the side of the compresor under the black plastic cover).
Jul 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
1,379 people viewed this question
Top Emerson Refrigerators Experts
Marvin
Marvin
Johnny 1000
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
