Washing Machines Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 series
I have a kenmore 80 series mod 110.21882000 It fills up with water and hums It will not empty the water. I change settings and speeds and nothing happens. I replaced the lid switch a few months ago. And today I replaced the motor coupling. While I had motor off I did spin the motor to make sure it was spinning freely it felt ok. What should I do next
Dan Webster
Level 3:
  • Washing Mach... Master 8,221 Answers
  • Posted on Jul 08, 2009
Dan Webster
Level 3:
Answers
8221
Questions
5
Helped
2379702
Points
25840
Look inside the pump. Smething might be in it. If you incorrectly installed the couplings too tight against the tranny or motor then the resulting bind will cause the problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore series 80 newer won't fill spin or agitate just hums on cycles and makes no noise on spin cycle
Are you sure the water is on and water is getting to the machine.
If there is no water the water valve will open & hum & nothing else will work till the tub is full.Check the little screens on the water valve behind the hot & cold hoses where they hook up the the machine they get clogged
up sometimes just pull them out and clean them. Hope this helps you
How many gallons of water does a Kenmore series 80 model 110 extra capacity plus washing machine hold at max and at 1/2 max
The Series 80 washer has a max capacity of 20 gallons. At the lowest water level setting you would have between 14.5 and 15 gallons.
My kenmore washing machine series 80 model stuck in soak cycle and will not pass to rinse cycle
This is usualy caused by the cold water not entering the machine. If you hear a humming noise it means the fill valve is operating but no water is present. Has some one turned the cold water off? Failing that the fill valve may be faulty and need replacing.
1helpful
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
1helpful
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
1helpful
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Kenmore 23012, spin cycle problem
This sounds like a broken coupler gear. I'm having the same problem with my Kenmore-80 Series. The machine fill up, pump out, but when I try to spin I get nothing and the I can hear the motor humming/grinding. I've heard the coupler gear is not expensive $35 or so and the repair procedure is not difficult, but I can't locate how to fix it. If you find any additional information, please send my way. I don't want to pay $150 or so to have it serviced.
Top Washing Machines Experts
john h
