Question about Kuppersbusch Glass ceramic induction hob with sensor touch controls and panon detection Metallic Cooktop
How to wire a hob to the mains
Nothing yet
Narinder Chhina
    New Friend:
  • 153 Answers
IN B.C. 30 INCH
Posted on Feb 19, 2015
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Won't switch on
a hob ??? or am i just stupid ??
Nov 23, 2011 | Bosch Cooktops
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Hotpoint
just a thought - check the connection block where incoming mains connects to the hob. these quite commonly burn out
Sep 07, 2008 | Cooktops
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Kuppersbusch Glass ceramic induction hob with sensor touch controls and panon detection Metallic Cooktop Logo
247 people viewed this question
Top Kuppersbusch Cooktops Experts
Colin Stickland
Colin Stickland
Bill Boyd
Narinder Chhina
Narinder Chhina
Are you a Kuppersbusch Cooktop Expert? Answer questions, earn points and help others
