2000 Jaguar S-Type Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P 1383 cougar 2000 - 2000 Jaguar S-Type
SPEEDY CAR WORK SHOP
Level 2:
  • Jaguar Expert 489 Answers
  • Posted on Aug 14, 2009
Jaguar Expert
Level 2:
Answers
489
Questions
Helped
159842
Points
671
P 1383 Variable Cam timing over-retarded (Bank 1) meaning the comprehensive component monitor (CCM) monitors the VCT position for over - retarded camshaft timing . The test fails when when the camshaft timing exceeds a maximum calibrated value or remains in an retarded position.
Cause :
* Cam timing imprperly set * Continuous oil flow to the VCT piston chamber
* VCT solenoid valve stuck open.
* Camshaft advance mechanism binding (VCT UNIT)
Hope that helps
Error code 1383 Ford contour 2000
this refers to the cam timing bank 1 , over retarded so the valves open slightly early, could well need the timing belt changed as could have jumped a tooth or streched
4helpful
Code 1383 and 1388
P1383= VVT over retarded bank 1.
P1388= VVT over retarded bank 2.
There is an issue with your variable valve timing system. It will need further diagnosis.
Center console from 01 Cougar fit 00 Cougar?
Yes it will fit.It will help. Thanks.
My 2000 mercury cougar will not start. The
http://www.automotive.com/2000/49/mercury/cougar/recalls/31929.html
How do I replace clutch in 2000 mercury cougar. 2.0L 4cyl
what do i have to do to change the clutch in a 2000 mercury cougar 2.0 thanks
I need a fuel rail sensor for a 2000 cougar. What
im sorry cougar has never produced a 2cyl engine re check your specs and repost
5helpful
Replacing my bank 2 catalytic converter - 2000 mercury cougar
what does code P0430 cat bank 2 mean? how many cat. converters does my car have? which one do i need? on my 2000 Mercury Cougar 2.5 liter auto trans.
How do I change light bulb in 2000 Mercury Cougar
wat light?? theres a lot of lights in the car
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
