The dryer is coming on but it won't move so the clothes can dry. When it does spin it moves very slow. It just started this within the past week. The loads are small and the clothes are soaking wet, the spin cycle on the washer makes sure of that.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings OTHER WISE CHECK FOR A LOOSE WORN BELT
