Sony STR-DE597 Receiver Logo
Question about Sony STR-DE597 Receiver
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
I want to hook up a Jensen js650 100 watt to the receiver?
Mike Smith
    Scholar:
    New Friend:
  • 65 Answers
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Posted on Feb 18, 2015
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
2answers
I have the sony str-de1075 reciever.i want to hook up a sub-woofer.but it only has 2 single port.not your reg.rca ports.what do i do..thanks..
Sorry but it's not clear enough what kind of subwoofer (passive or active) you want to use. The passive one has no power supply connection, the active one has a power supply connector and the audio connector can be connected at the "audio out" for the subwoofer, at the rear panel of your STR-DE1075. Take a look at this photo:
In case you need a user manual for your receiver, here is an official link.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Sony str-de97 fm/am receiver
you need to change the audio amplifier iC´s damaged
1helpful
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
My subwoofer and surround speakers don't work. However the main speakers work.
sony... its in stereo mode. hit the movies, music or afd buttons for the receiver
Flushing "PROTECT" on the screen of a SONY STR DG 910 Receiver
Try connecting one speaker at a time. The "protect" indicates a short or improper impedence (ohms) in one of the speaker lines. it may not be directly shorted, but I'll need to know what you have hooked up for speakers. Also, do you have any electronic meters?
Need a remote for for Sony STR-DE597 Receiver.
Bad news, most every universal remote is for tv, vcr, dvd, cable box, and nothing else. you can goto sony.com or check ebay for a new one.
2answers
How do i hook up my ipod to a sony STR-DE597 6.1 channel reciever?
have u checked the COMPATIBILITY of the IPOD with your system(receiver/amplifier). the software of some models is not compatible withyour respective receivers.
Go to their sites for software upgrades.bye.
Top Sony Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
