You can try to download a pice of Blu-ray player program such as Leawo Blu-ray Player which can decode DVDs easily and it is region free.
You can check more info here:
How to Play Blu-ray on Laptop
According to all my research, your computer does NOT have a blue-ray capable DVD drive. You cannot watch blue-ray movies on it.
SOURCE: acer 5536 - blu ray disc doesn't want to play
If you look at the sticker, you see a small astrix beside the blu-ray bit....then look top right of the sticker and it says *specifications vary depending on model...chances are you dont have the right spec and actually didnt get it. the acer aspire 5536 is one example, sorry
SOURCE: Blu-Ray not working on Acer Laptop.
here is the specs on that drive .. it does not support blu-ray ... so you are right .. looks like acer gave you the wrong drive .. hopefully they will replace it with the correct one .. you can burn DVDs with this drive so its a nice unit, just the wrong one ..
http://support.dell.com/support/edocs/storage/197276/spec.htm
SOURCE: QuickPlay won't play one blu ray disc but plays all others.
I would take the movie back. We have found DVDs which cause similar problems.
SOURCE: HP dv9000 won't play Blu ray DVDs
The problem is QuickPlay. Some discs work, but those that didn't, played just fine on my PS3. I had to buy Cyberlink PowerDVD 9 Ultra (10 Ultra also plays Blu Ray), and now, they all play on my HP dv4 laptop. Updates won't matter. Don't use QuickPlay, it's very "fical". Hope this saves you time & frustration. It's not you, it's not your Blu Ray drive, or drivers, it's simply the software/program (QuickPlay) that is the problem.
SOURCE: acer aspire 6935g wont play blu-ray discs, will
You need to download K Lite Codec Pack (Its Free) and you can install it via....... or you can try googling it.
http://www.codecguide.com/download_kl.htm
It contains all the different audio and video codecs. Your computer might not play it because it doesnt have a blue ray codec by default
Please post your feedback and Vote if the problem resolved as per your satisfaction.
