Question about Panasonic SR-SH15PS 8-Cup Rice Cooker
Rice cooker stopped working after one month's use
I have an aroma 20 cup rice cooker. I bought it an year ago but started using it just a month back. I have been cooking rice in it everyday but today the rice got burned badly and got stuck to the bottom of the non stick cooking vessel. I added the same quanity of rice and waterI switched it off at once, removed therice and cleaned the vessel. Then I tried to cook rice once more but the cooker is not working anymore. Any suggestions as to how to fix it?? Thanks Hi,My cooker stopes working after 1 year.I have no clue how to fix it.Can any body help me?Rob
Posted by shalem on
  • Anonymous Mar 15, 2014
    not able to fix the belt in aroma rice cooker
earl norman llanera
  • 871 Answers
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
Posted on Jan 17, 2008
  • Cyndy
    Cyndy Jan 16, 2019
    Thank you! But actually I have not used a cooker in a long time, because I don't have one. I am dog sitting at my daughter's and her husband uses it every day. Unfortunately, I am in the middle of nowhere and cannot get out so easily...
IM IN LONDON. I PURCHASED AROMA RICE COOKER THROUGH AMAZON.120V RICE COOKER. How to use it here in London?
Look on the information label to see how many amps it draws at 120 volts. Multiply the amps by 120 to get watts. Next you'll need to get a transformer that will handle the watts when changing 240 volts to 120 volts
Oct 10, 2014 | Aroma Rice Cooker ARC-150sb 20-Cup Cooked...
Where in San Francisco may I have the latch repaired on my 10 cup Aroma Rice Cooker/Steamer, model is ARC 850?
Hi, you have to contact Aroma-House on 1-800-276-6286 to request for their repair center or nearest center to you in San Francisco....
Sep 03, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Water to rice ratio in an Aroma ARC 1000
Water to rice ratio is usually the same regardless if you have a rice maker, or are cooking it in a pot on the stove. 2 parts water to 1 part rice works everytime.
Jun 08, 2010 | Aroma ARC-930 20-Cup Rice Cooker
ARC-838TC 20-Cup Rice Cooker: Lost the instructions on how to use the aroma arc ...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
May 18, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
ARC-930 20-Cup Rice Cooker: Do I have to use water to steam my rice in an arom...
heatman101
May 17, 2010 | Aroma ARC-930 20-Cup Rice Cooker
My Aroma ARC 930 Over cooks white rice
try 2 cups rice 3 cups water using Medium grain rice, your adding too much water
Dec 31, 2008 | Aroma ARC-930 20-Cup Rice Cooker
Lost rice measuring cup
http://www.retrevo.com/support/Aroma-ARC-838TC-manual/id/21195bh127/t/2/
You can download the manual. The standard rice measuring cup is 180ml (one cup in the US is approximately 240ml).
Nov 26, 2008 | Aroma ARC-838TC 20-Cup Rice Cooker
Panasonic SR-SH15PS 8-Cup Rice Cooker Logo
840 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Colin Stickland
Colin Stickland
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
