HP LaserJet P2055d Printer Logo
E
Emmanuel Chivatsi Posted on Feb 14, 2015
Laserjet p2055d.when print 1doc it prints extra blank page. what could it be?
I tried to reset but could'nt get the solution, plse help.
robert charles
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 14, 2015
robert charles
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
3186
Points
25
I had the same problem. Try adjusting the setting to fit on one page (did not work for me on my hp but worked on my brother MFC) or remove the device and reinstall with updated drivers
We have a Hp laserjet p2050, when i get the print , printer showing a some device error, press ok, then printer accpect the command ,so how can resolve the issue.
does this happen in all jobs or just certain jobs.Try printing a config page by going to reports and config page, enter.
How can print power point slide in hp laserjet P2055d?
why i can't print power point slide in laserjet P2055d?
Hp laserjet printer p2055d print blank pages what is the problem?
Probably a bad ink cartridge. Remove the cartridge and clean the face of it with alcohol to remove dried or clotted ink.
Dave W.
My printer prints out a blank page if im trying to print a pdf from adobe reader. its hp laserjet.
it sounds like your printer cannot translate the the graphics being sent from your computer.
It may be that one of your printer settings is not set correctly.
Or, it may be as simple a solution as updating your driver for your printer.
Try here for a driver for Laserjet P2055D:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3662055&taskId=135&prodTypeId=18972&prodSeriesId=3662052&lang=en&cc=us
If this is not your model, search for your specific model on this HP website.
Note there are also firmware upgrades for the P2055D printer.
Cheers,
Steve
2answers
HP 4500 Printer blank pages
Hi over the years on working on these printers I have found the transfer belt-kit causes this model to print blank pages i would try this
hope this helps
James
1helpful
Hp laserjet 1300 prints extra blank page
did you try the hp laserjetIII driver
1helpful
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
k24674
Grand Canyon Tech
Grand Canyon Tech
