Question about Microsoft Windows Vista Business Edition for PC
I'm getting this message every few minutes on a Vista system. Acrord32.exe-No Disk "there is no disk in the drive\Device\Harddisk4\DR4.
I've uninstalled Adobe Reader chrome browser extension with no results.
  • 1 more comment
  • M Beutner
    M Beutner Feb 15, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • M Beutner
  • M Beutner
Daniel Johnson
    New Friend:
    Problem Solver:
  • 19 Answers
If you recently attempted a clean installation and are just now getting the error, Try a system restore point that goes back to before the error was occurring. Easiest fix! After you have done that, I would uninstall Adobe reader and REBOOT. Download and install Glary Utilities from ninite.com and let it clean the registry. After successful reboot without the error, create another system restore point. Next, attempt the installation of Acrobat again. Reboot and see if you get the error. If you do, go back the recently created restore point. If you are still experiencing the error you could try using revo uninstaller to completely remove the buggy corrupt program and it will also allow you to clean the registry as well. Best of luck.
Posted on Feb 16, 2015
M Beutner
    New Friend:
  • 73 Answers
These instructions apply If you have "Adobe Acrobat Reader" installed, not if you have the paid for, full suite "Adobe Acrobat".
1. Completely uninstal "Adobe Acrobat Reader"
more details (troubleshooting):
https://forums.adobe.com/thread/755658
2. Reinstall (if you so choose) "Adobe Acrobat Reader"
http://get.adobe.com/reader/
or use an alternative (less bloated) PDF-reader:
http://www.tracker-software.com/product/pdf-xchange-viewer
Posted on Feb 15, 2015
  • M Beutner
    You probably should scan your browsers for malware as well:
First boot of Win 7. New PC build
Hi.
First of all when you are in the BIOS and have set the DVD/CD drive as the first boot device make sure you save the settings before you restart the computer as it will not remember the changes if you don't.
Make sure that the lens on the CD/DVD drive is clean and also make sure the Windows 7 install disk is clean and free of any finger prints.
make sure that you keep tapping a key when the drive spins up as sometimes people miss the "Press any key to boot from CD/DVD" message.
If you still can't get the disk to boot then try the install disk in a working PC and see if that reads the disk. If it does then the optical drive could be faulty or does not support DVD format.
Regards.
Feb 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Boot mgr is missing,also when I try to re program from o/s vista disc after installing updates ,I get the message could not prepare to boot into next stageof installation,restart installation,HELP
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Computers & Internet
Please help me..i have a aspire one d260 netbook..the problem is bootmgr is missing..it has no cd drive and i dont have a external cd drive to use.. how can i fix it using only a usb flash drive..how can...
You might have to take it to the shop. Lesson learned. Never buy a computer without a CD Drive because one day the system is going to croak.You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
May 29, 2012 | Acer Aspire One D260 Netbook
When i start my computer a message came that 'disk
No your operating sytem or boot files have a problem. Something is missing or corrupt in the operating system or boot files.
Try the steps below.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 11, 2012 | Compaq Computers & Internet
HP recovery disks don't boot!
Sounds like you need a windows vista operating system disc. The recovery discs set your system back to factory settings like when you first brought it home from the store. But to me, the system is bloated with all the software and trial junk that you don't need. If you can get your hands on a Vista Operating System Disc, then do a clean install from it. Just make sure your Certificate Of Authentication (COA) sticker is readable so that you can activate the vista once you've got it loaded. If you can't get your hands on a system disc, take it to a computer repair shop, I would think you could find one that will load the operating system for $60 or less.
Mar 15, 2012 | HP Pavilion dv6-1030us Notebook
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
Low disk space winsxs is 10 gb how do I delete this file pls
The bad news are that i don’t recommend doing any manual removals on winsxs folder. Such a step could probably make your applications non-workable or even break your system!
If you have Vista sp1 installed use the vsp1cln.exe : The utility removes all Vista SP1 uninstall files and by using it you can reduce few gigs.
To run vsp1cln.exe:
  • Press on vista start button type cmd.exe and hit on enter.
  • hen enter the following command:Vsp1cln.exe and press enter key
  • You will be asked to confirm your action , just press “Y” and after few minutes your winsxs will be smaller.
Other ways to reduce the winsxs folder:
  • You can uninstall non needed application
  • If you have office 2007 installed , and you can get later distribution like with sp1 included – uninstall your entire office, and install the version that includes sp files.
Apr 13, 2010 | Microsoft Windows? Vista Home Basic...
Winload.exe
Hi there.
When you turn the laptop on, keep pressing Alt+F10. This should open the recovery program. Follow the on-screen instructions for factory settings.
Let me know if this does/doesn't work.
Tim
Apr 19, 2009 | Acer Aspire 3680 Laptop
Cannot download pictures to my computer from my fuji sd card
hecht:
If you are trying to download to a computer, then make sure you are not trying to go to a cd.
Try to write to the dr4 (not sure which one this is) with out the camera connected. If you can write to the hard drive with not problem, then try the following.
Make sure you are not trying to write to the camera.
Remove the card from the camera, and use a card reader.
Apr 30, 2008 | Fuji FinePix A600 Digital Camera
Microsoft Windows Vista Business Edition for PC Logo
171 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
