Try :
access recovery mode holding volume up+home button+power
video on unrooting:
How to unroot Samsung Galaxy S2 if the root process fails
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: MY SAMSUNG GALAXY S2 WONT CHARGE
Try connecting your S2 with the usb cable provided to your desktop/laptop. If it starts recharging, then it is definitely your charger thats done for. Get a new charger...
SOURCE: Cannot charge Samsung Galaxy S2
first, test th charger with another phone to confirm if its working or not.
If the rempte is working, then it means the charging port of your phone is defective and needs to be replaced.
Regards.
Testimonial: "Thanks!"
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
SOURCE: How do i enable cookies on Samsung galaxy s2
While you have your web browser open, touch the settings button that has the lines next to the home button, then it should have more options like bookmarks, Windows, etc.. there should be settings, touch that and scroll down til you see accept cookies. Hope this works.
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
