Question about Canon Office Equipment & Supplies
How do i quit service mode after entering service mode? canon e400
I'm trying to reset my ink catridge,so I follow the instruction of entering service mode from http://quangmanh.vn/p_detail/14031-reset-may-in-canon-e400.html. But after I entering the service mode,I realised it's too hard to find the service tool for e400! So now I'm looking for the way to quit service mode!Pls help.
Penzance Computers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 2,003 Answers
Switch the printer off and on again!
Posted on Feb 14, 2015
Testimonial: "tried it won't work"
  • Anonymous Feb 14, 2015
    tried it dont work ,support code 5012 shown
Service error 6500 ix4000
The Canon website indicates that is a hardware problem, there's nothing i can do. You call a technician or the canon help support. This is the description of the code:
Other hardware error [6500] - Logic board ***'y (QM2-3393 / QM3-1654)
Mar 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
HAVE CANON F60 MULTI PASS. ERRPR IS WASTE INK NEAR FULL SEND BACK TO CANON WHY CAN'T I REPAIR IT MYSELF
It is not recommend you try to fix it yourself, you can try to manually reset the error code, but if the waste ink is really nearly full and you reset it, it could damage the printer pretty severely. Here are manual reset instructions for a similar model printer, it should work on the F60 if the buttons are the same:
1) Enter Service mode by pressing: menu-copy-#
2) select: Test Mode
3) select [8] printer test in test mode
4) select 3 [eeprom clear]
5) select 0 [ink count]
6) press the [stop/reset] key (returning to the state of 3), and press the [on/off] key
If that doesn't work try this one:
1) Enter service mode by pressing MENU,COPY,SCAN,COPY,COPY
2) Select TEST MODE
3) Select (8) PRINTER TEST in TEST MODE
4) Select 3 (EEPROM CLEAR)
5) Select 0 (INK COUNT)
6) Press the SET key
7) Press the (Stop/Reset) key, returns to the state of 3, then press the ON/OFF key
Sep 15, 2010 | Canon Office Equipment & Supplies
When i refill the catridge i receive the following message: replace the catridge
You can try to reset the ink level...first you need to restart your Kodak printer by switching it off/on. Then goto the "Start" menu on your computer and select "Control Panel" and click "Printers and Faxes." Right-click on the Kodak 5300 printer icon, then select "Properties". Select the "Services" tab, then on "Service this Device." After that in the next window select the "Estimated Ink Level" tab. This will show you the re-calculated ink level of your printer cartridge after your restart.
May 23, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer catridge is low i am refilled that with the help of service man, but unfortunately catridge ink was spread over the paper so solve this problem
It is the protection counter error, the amount of ink discharged by the printer has reached the maximum value allowed and the printer requires to be reset.
To clear the error follow the instructions you can find here:
http://myprinter.altervista.org/simplefaq/mysimplefaq.html#counter
Once the error has been cleared the printer returns operative, however to avoid further problems you should check and clean the waste ink pads where discharged ink is stored.
To reach the pads you have to disassemble your printer, you can find an exploded diagram here:
http://www.compassmicro.com/parts.cfm
Jan 19, 2010 | HP LaserJet 1020 Printer
Absorber nearly full. canon PIXMA MP130. How do I empty it?
To Clean Waste Ink Absorbers:-----------------------------
  • Open the cover ( the cover you open to replace the catridges ).
  • Locate the Waste Ink Pads which are situated in the or under the Catridge Slider.
  • Dry up Waste Ink Pads ( You should wear Gloves when holding them).
  • Rinse the pads with Alcohol and make them dry.
  • Replace Pads .Then Set them. Make sure they are sitted properly.
Thank you Sir, I hope I helped you. Have a nice day.
Sep 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
MP130 Ink waste tank is full how do I empty it
To reset the Waste Ink Counter:---------------------
  • Press Menu----------- Scan -------------- Copy----------- Scan, to enter Service menu.
  • Scroll to option " Service Menu Counter Access ".
  • Press OK.
  • After entering Scroll to " ABS-M DOT COUNT ".
  • Use arrows to reset the value to ZERO.
  • Press Stop or Reset.
Thats the Solution.
To Clean Waste Ink Pads:-----------------------------
U053 Error
Use the correct ink cartridge referring to the model number indicated on the printer box or the instruction manuals. Please refer to below website: http://support-sg.canon-asia.com/contents/SG/EN/8000660401.html
May 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Ink absorber problem
Find the similar type and follow this instructions.
Mar 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
Waste ink tank full
try resetting printer as follows.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jun 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
1,009 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
