SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
SOURCE: error code f2:e1
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%^
SOURCE: KitchenAid Superba Gas Range error code F3 E0 when
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened
Replace oven temperature sensor or fuse
Good luck
SOURCE: KitchenAid Model KESC307 has a broken oven heating
Hello Tgilreath,
I understand that you are having a problem with you KitchenAid range. The oven element is broken and needs replaced and you would like to know the cost of the element.
I can instruct you on how to change the element in your range. However, I do not know if it is the top of bottom element and the change procedure is the same on both of them. However, when looking up the element to tell you where you can purchase and the cost I came across many different KitchenAid models that contained the numbers you gave. There should be more letters and numbers on your tag for the model.
The following is steps are how you change out your element:
1. Disconnect the power to the unit
2. Remove the lower back cover on your range (the one that sits directly behind your oven)
3. Locate the two prongs on the bad element sticking thru the oven wall and remove the wires
4. In the oven remove the racks
5. In the oven remove the two screws holding the element in place
6. Remove the element by pulling in forward
7. Install new element in Reverse
You can locate the element on Sears Parts Direct at the following web-page, however you will need the full model number http://www.searspartsdirect.com/partsdirect/part-model/kesc307?pathTaken=modelSearch&prst=0&shdMod=kesc307 You may also reply to this thread and I will get you a part number and the exact page you need to order the part.
Thank you for choosing FixYa.com
Justin
Hi
F2-E1 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
Hi
Error
code F7-E0 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
Daniel
