Hw do i remove error code E4
Because its right cold and nice but latter it show tht error code.whi Le is cold
Richard Slade
    Problem Solver:
  • 21 Answers
E4: Indicates lack of refrigerant, or the compressor is not running, or the thermistor is out of
calibration.
Action: Check that the compressor is running by listening.
If it is apparent that the compressor is running, then check the
temperature difference across the evaporator.
i.e. Measure temperature of return air at inlet filters and
measure temp. of discharge air at grilles. This temp diff.
should be 14 to 18 C. with fan on hi speed. If temp diff. is less than this,
suspect lack of refrigerant.
Fit a suction gauge to access valve at rear of unit. See fig 12. On a 35C
outside temp. then suction should be 380 to 450Kpa.
Good luck
Posted on Feb 15, 2015
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
The LE error code keeps flashing why?
LE means level error. The water fill timer timed out before there was enough water in the machine to clean the clothes. Try this:
  1. Turn the hot and cold water supply taps, located at the end of the fill hoses, as far as they will go toward the "Open" position.
  2. Move the washing machine away from the wall, and examine the hot and cold water pipes for kinks, twists or other obstructions.
  3. Unscrew the fill hoses at the washing machine, and inspect the small plastic screens inside for signs of an obstruction.
  4. Check the water pressure in your home; a reading lower than 30 psi might cause the fill times to extend beyond the time the washing machine is programmed to wait. Slow flowing faucets and shower heads are a sign of low water pressure.
  5. Call for service.
Apr 20, 2015 | Maytag Neptune Washing Machines
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
It seems the compressor is not switching on the air con blows cold air but not as cold as it should be. It shows an E4 on the display.
Is this a house, a car, a portable AC? We can't help you look up error codes without a model number. Details pls.
Sep 25, 2014 | Heating & Cooling
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
Ā·Close the door!
Ā·Check the door lock switch
Ā·Check the door latch
Ā·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
