Question about Electric Jazzy 1115 Power Wheelchair
Jazzy 115 will not move. Controller has 3 red and one amber bar flashing
Posted by Lonnie Stanley on
oregoon
  • 175 Answers
Pride doesn't make a Jazzy 115. Please check your chair and owners manual to get the correct model so we can help. How old is the chair? The flash codes you are getting depend on the model, year it was born, and the tkype of controller installed.
Also, the flash code should be literally, flashes. 2 lights flash twice, stop, then go again, etc. They all mean something, so repost with more info please.
Posted on Jul 08, 2009
  • oregoon Jul 08, 2009
    Looking at past models, you probably have the Jazzy 1115 and those came with a PG Drives Technology Joystick/Controller. These will flash out a code when it senses a fault in the system. Here's the address for the fault codes http://www.pgdt.com/scenter/diagnostics/...
    Yours indicates a right motor disconnect and recommends checking the snap-on connections to that motor. A disconnect code can also occur when the motor shoots craps. An open winding would look like a disconnect to the controller and give this fault code. Sometimes the VSI controller will give you a false fault code when motors go out, so I should add that it could be the left motor, and not the right. Disconnecting the motors and swapping the connectors (left motor gets right motor supply connection, etc) and then restarting the chair should show a 2 red bar fault to indicate a left motor(which is actually looking at the same right motor but the computer thinks it is the left because of the switch of connectors)disconnect. If it does, then it is probably the right motor that's bad. If it's under warranty, Pride will replace it, if not, it's about $900.00, but if you got the chair through your insurance, they will pay for all of most of the repair cost. If you didn't, and don't have a thousand bucks lying around, you could try taking it to a reliable motor repair shop. They can test the motor to be sure it's bad, and for anywhere from $100 to $200, fix it good as new.
    These motors rarely fail like this, unless the chair has been driven in conditions not suited for it. The usual suspect is the owner got it stuck in wet grass, mud or sand and tried to drive it out of trouble. This really stresses the motors and leads to early failure. If you get into sloppy terrain, get out of the chair if you can, or seek help from someone to push you out. Good luck.
My jazzy select GT lights blink rapidly 8 times then stops and then repeat wheelchair and I will not move
An 8 bar flash indicates a controller fault. The computer controller is under the front cover of the power wheelchair. Check all the connections here and at the batteries. You may need to replace or have the controller rebuilt. Hope this helps.
Feb 20, 2016 | Select Health & Beauty
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Dec 21, 2014 | Pride Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 1113 Unit has a full charge, but won't move. Battery indicator LED's go from empty to charge a couple times then flash the red and yellow. Think it might be the throttle pot. If so is it possible to...
Go ahead and try this web site.It will give you the flash codes and narrow down your search to finding the problem.http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Jan 22, 2011 | Pride Mobility Products Jazzy 1113 ATS
1 red and 3 amber lights flashing after stopping and goes around in circle on a jazzy 1121 powerchair
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
The powerchair going in circles may indicate a motor is bad and needs to be replaced.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Aug 23, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My jazzy 1115 joystick controller flashing and the chair doesnot move .
1. make sure it's not still pluged in recharging.
2. make sure both free wheel levers are engaged.
if the jazzy is still flashing and not moving refer to the flash code in your owners manual. count the flashes between pauses. get back to me if you don't have the manual. Mike
[email protected]
Nov 20, 2009 | Electric Jazzy 1115 Power Wheelchair
Jazzy 1121 power chair won't go
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Apr 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 01, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Electric Jazzy 1115 Power Wheelchair Logo
532 people viewed this question
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
barrybam
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
