Question about Magnavox ZV427MG9 DVD Recorder/ VCR
Can i convert at PAL video with this machine?
Would like to buy a PAL VHS tape from Europe and convert to DVD
  • Magnavox Master
  • 6,255 Answers
The version of the ZV427MG9 sold in the U.S. only supports NTSC video files. Thus it won't play a PAL VHS tape.
If you find a similar version sold in Europe, that would probably play PAL videos. However, if you used the tape to DVD dubbing feature, the DVD would still have the PAL format. I'm not even sure that a video capture device with video conversion software on a computer would do what you want to do.
I wish that I had better news for you.
(The video would also matter. If you are trying to convert a commercial video (ex: a movie) to DVD, the dubbing feature doesn't work due to copy protection.)
Posted on Feb 14, 2015
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
Honestech tvr video recorder
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
May 09, 2013 | Fulltone Ruby GrabBee Deluxe USB 20 NTSC...
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
Do you have video players that I can use to playback analog v8 tapes (PAL and NTSC) and record them in digital format?
I went to the local Sony store and they agreed to convert my 8mm home video tape into digital, DVD format for less than 15 bucks!
Oct 24, 2009 | JVC KV-V8 VHS/S-VHS playback VCR
Playing VHS tapes from Belgium?
Yes, having invented TV here in America, we have always used the NTSC format. It is not compatible with the other formats. There are some commercial VCR's that can play any format, but very expensive of course. If it is something important that you need, take it to a TV editing service that can convert it for you.
Feb 07, 2008 | GoVideo DV1030 DVD Player/VCR
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
NTSC tapes to PAL DVD
Hi, I suggest you to contact a company that will convert the NTSC VHS to DVP Pal for you. This will be easier and more effective (and unless you have MANY tapes, this will be cheaper). I did a quick search and I found this place: http://www.video-convert.co.uk Please let me know if this is helping!
May 23, 2007 | HP DC4000 (Q2125A#ABA) DVD±RW Burner
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
Magnavox ZV427MG9 DVD Recorder/ VCR Logo
Top Magnavox Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
