Question about Mitsubishi XL8U Multimedia Projector
Projector automatically shuts off immediately after turning it on
After I turn on the projector, it begins to work....I see the light projected on the wall....and a couple of seconds later - it shuts down (no light) and green light flashes (red steady on)
Posted by Frosty T on
  • ActiveHawk Nov 15, 2007
    I have the same problem except the projector starts it's shutdown process after a few seconds before the lamp comes on. I replaced the lamp and that didn't fix the problem. I am just now searching for another cause/solution.
Anonymous
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug
Posted on Dec 10, 2007
Anonymous
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Bulb works, projector turns on, though it immediately shut
check the fan if it works as will as clean the filter.
Aug 18, 2012 | Epson EX31 Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Dear sir , I am connecting my loptop to LCD Toshiba TLP-X3000 projector but project showing a red light and it is not turning on.Pls tell me solution immediately.... Soban
you should try shutting down your laptop, plugging in the interface cable for the projector and then powering on the laptop. This solution works with some projectors and all HDMI computer to External video source connections. (I say all because I have yet to find a combination that this didn't work on for HDMI)
Dec 09, 2010 | Computers & Internet
I replaced my bulb and it does not seem to be working. The projector power turns on then shuts off immediately
a short circuit in one of the power lines on the mainboard is most of the time the reason for immediate shut down
check all smd capicitors
Apr 03, 2010 | Eiki LC-XE10 Projector Multimedia...
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
When I turn on my EP7120 it starts to warm up and then the 2 warning lights come on automatically. (Red bulb and overheating light) I turn it off and let it cool but when I turn it on the red lights come...
Is the cooling fan working? (If not, then that's the problem).
Check that the intake grid for cooling is not blocked with dust and that it has adequate room to draw in air.
Mar 17, 2009 | HP Ep7120 Multimedia Projector
Mitsubishi XL8U Multimedia Projector Logo
1,012 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
