Question about Xitel INport Deluxe
Lost registration code for xitel inport device
I lost the code that came with my xitel inport device and i need to install it on a new computer
Posted by webbermez26 on
Icon Graphics
  • 38 Answers
Most of the time the package of the CD the code was on it try to locate the code their else the email with do the rest.
Posted on Jul 08, 2009
apjohnson71
You can use audacity it is compatable with xitel inport and its free to http://audacity.sourceforge.net/
Posted on Jan 19, 2011
How does a customer with my problem get avoid having to purchase a new device and avoid the trialversion? I guess getting around the registration number is out of the question, but after using this device...
if you have purchased a program and want to install it on a new computer, contact the program company and talk with them
they will have the purchase and registration details on record and will advise on how to download and install on the new computer
they may also have a facility where by you give them permission to access your computer remotely and install it all for you
Nov 11, 2017 | Xitel INport Deluxe
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Lost my xitel inport registration number
To find the registration and code key numbers for software on your computer, go to www.download.com and download "Belarc Advisor" it is FREE. It will scan your system and bring up a report screen showing all your hardware and software, including software license numbers and code keys. It will also tell you which MS patches and fixes are installed or missing.
Apr 13, 2011 | Xitel INport Deluxe
Need s registration key for xitel inport to put on my computer
I bought my'n from the home shopping channerl for $89.00
works excellent.
Feb 06, 2010 | Xitel INport (HFLI1X1) Audio Input
Lost CD
heres the link where you can download the software that you it will take you directly to xitel product support
http://www.xitel.com/USA/support_inport_vista.htm
Nov 23, 2009 | Xitel INport Deluxe
I lost ALL sound when Iinstalled Xitel's Inport
Have you trying to rollback using windows sistem restore
Aug 23, 2009 | Xitel INport Deluxe for PC
Lost my activation code for xitel inport
lost xitel import registration key number
Dec 11, 2008 | Xitel INport Deluxe
INPORT Installed, Sound Disappears
The Xitel site http://www.xitel.com/USA/support_inport.htm says when this happens, " 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback."
Jul 20, 2008 | Xitel INport (HFLI1X1) Audio Input
Xitel INport Deluxe Logo
605 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Bill Boyd
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
