Have not tried any combinations yet
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
SOURCE: i am installing a harbor breeze ceiling fan i
Please try this link below because this might help you. You will see lots of link from the site just select the better solution that can give you.
Just click HERE so that you will be directed to the site:
Thanks
